Home » Eclipse Projects » BPMN 2.0 Modeler » Message Flow Connection rules and Task's attributes
Message Flow Connection rules and Task's attributes [message #1003977] Tue, 22 January 2013 05:56 Go to next message
Hassan BAZOUN is currently offline Hassan BAZOUN
Member
I has few remarks concerning the BPMN Modeler:
1- According to the BPMN 2.0 spec a process can be referenced by 0 to many participant.
So if we follow the following scenario:
  • create two pools (Pool1 and Pool2)whose participants reference the same process P1.
  • add task T1 to Pool1
  • add task T2 to Pool2
  • try to connect the two tasks using a message Flow
Expected result: a message flow is connecting the two tasks
Observed result: you can't connect them by a message flow but by a sequence flow
2- In the Properties window of user Tasks and service tasks there is no attribute for Resource Role List (Inherited from Task -> Activity).
For me remark 1 is a (major and sometimes blocking) bug.
Is remark 2 a bug?
Thanks in advance.
HB
[Updated on: Tue, 22 January 2013 05:57]
Report message to a moderator
Re: Message Flow Connection rules and Task's attributes [message #1005523 is a reply to message #1003977] Fri, 25 January 2013 18:48 Go to previous message
Robert Brodt is currently offline Robert Brodt
It looks like this has been fixed recently - can you give this another try?
The Resources list (at least if you're using the jBPM5 Target Runtime) is called "Actors". This is only available for User Tasks.
If you're using the "None" Target Runtime, it looks like you are correct - they're missing Sad I'll have this fixed in next week's build.
Previous Topic:Missing name attribute in dataInput tag
Next Topic:Sequence Flows connection Bug
Current Time: Tue May 21 20:21:39 EDT 2013
Powered by FUDForum. Page generated in 0.01653 seconds
