Home » Modeling » GMF (Graphical Modeling Framework) » 'diagramLabel' of 'Feature Label Mapping false'
'diagramLabel' of 'Feature Label Mapping false' [message #1005520] Fri, 25 January 2013 16:15 Go to next message
Vanessa Kreitz is currently offline Vanessa Kreitz
I created the gmfmap, but now I got an error message and can´t fix it.
"The required feature 'diagramLabel' of 'Feature Label Mapping false' must be set"
The error is in the gmfmap, but I can´t find 'diagramLabel' nor "'Feature Label Mapping false' anywhere.
Can someone help?
Re: 'diagramLabel' of 'Feature Label Mapping false' [message #1005676 is a reply to message #1005520] Mon, 28 January 2013 04:06 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph Gerbig
rightclick the root of gmfmap. Select validation. The error will pop up in a dialog. Select the error in this dialog. Press OK. The model element for which the validation failed will be selected.
Ralph
Re: 'diagramLabel' of 'Feature Label Mapping false' [message #1006296 is a reply to message #1005676] Wed, 30 January 2013 12:42 Go to previous messageGo to next message
Wow, this tip helps now and for the future.
Thank you again, Ralph!
Re: 'diagramLabel' of 'Feature Label Mapping false' [message #1011823 is a reply to message #1005520] Wed, 20 February 2013 05:15 Go to previous message
web Mac is currently offline web Mac
Vanessa Kreitz wrote on Fri, 25 January 2013 22:15
... I got an error message ...
Can someone help?
So more specific in your .gmfmap file in the Feature Label Mapping (Top Node Reference > Node Mapping > Feature Label Mapping) Properties there is a Key-Value pair named 'Diagram Label' in the group 'Misc' where you have to choose a reffering Diagram Label which you already should have defined in the .gmfgraph file. Once you set a Diagram Label here this error should be gone when you rightclick and validate the .gmfmap file.
Hope this helps anybody who's searching for the same error message Smile
Previous Topic:Generated Code of ViewMap
Next Topic:Problem in generating Code
Current Time: Thu May 23 10:40:26 EDT 2013
Powered by FUDForum. Page generated in 0.01686 seconds
