| [CDO] NPE at org.eclipse.emf.ecore.util.EcoreUtil.getURI(EcoreUtil.java:2984) [message #1005411] |
Fri, 25 January 2013 05:43  |
Erdal Karaca Messages: 620 Registered: July 2009 |
I have a transaction with a new object and am about to commit that transaction, but getting the following exception:
Caused by: java.lang.NullPointerException
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.provideCDOID(AbstractCDOView.java:1134)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.provideCDOID(CDOTransactionImpl.java:2237)
at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.writeValues(BaseCDORevision.java:893)
at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.write(BaseCDORevision.java:236)
at org.eclipse.emf.cdo.spi.common.protocol.CDODataOutputImpl.writeCDORevision(CDODataOutputImpl.java:381)
at org.eclipse.emf.cdo.spi.common.protocol.CDODataOutputImpl.writeCDORevision(CDODataOutputImpl.java:372)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.requestingCommit(CommitTransactionRequest.java:178)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.requesting(CommitTransactionRequest.java:128)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequestWithMonitoring.requesting(CDOClientRequestWithMonitoring.java:91)
at org.eclipse.net4j.signal.RequestWithMonitoring.requesting(RequestWithMonitoring.java:165)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedOutput(RequestWithConfirmation.java:119)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:104)
at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:235)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:431)
at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:110)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:518)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.commitTransaction(CDOClientProtocol.java:393)
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:71)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1181)
... 5 more
Any hints where to look at?
FUDForum. Page generated in 0.02030 seconds
