Home » Eclipse Projects » Hudson » How to configure a Global project in Hudson (Handling multiple projects on Hudson)
How to configure a Global project in Hudson [message #1005276] Thu, 24 January 2013 14:04 Go to next message
sidharth lala is currently offline sidharth lala
Current configuration:
We are using Hudson 3.0.0, Apache tomcat, SmartSVN , JDK inno setup, and ant script, basically build.xml which helps to trigger the build and convert the source package to an installer .exe.
Script contains the svn location where the code is checked in. If sometimes we have a build request from a different team, then we need to share their code to the respective svn location. So, that we can build the source java package to an installer.
New requirement : That Active directory plugin should be used and any team can login to Hudson , which belongs to the added domain and further they can build there project separately.
Thanks for the help.
Re: How to configure a Global project in Hudson [message #1005335 is a reply to message #1005276] Thu, 24 January 2013 17:22 Go to previous messageGo to next message
Steve Christou is currently offline Steve Christou
There is a Active directory plugin (version 1.31-h1) which should allow for the added security you are looking for.
 * @author Steven Christou
 * @dev    Hudson-ci
Re: How to configure a Global project in Hudson [message #1005351 is a reply to message #1005335] Thu, 24 January 2013 20:51 Go to previous message
Winston Prakash is currently offline Winston Prakash
Also you could use Project-based Matrix Authorization Strategy as explained here
http://www.eclipse.org/hudson/the-hudson-book/book-hudson.chunked/ch04.html#section-security-authorization-project
Winston Prakash
Eclipse Hudson team
Previous Topic:Maven Build : ArrayIndexOutOfBoundsException
Next Topic:Hudson 2.0 CVS checkout issue
Current Time: Wed May 22 06:39:05 EDT 2013
Powered by FUDForum. Page generated in 0.01713 seconds
