Home » Modeling » EMF » Generic valueType for EMap
Generic valueType for EMap [message #1004758] Wed, 23 January 2013 20:19 Go to next message
Jason Roberts is currently offline Jason RobertsFriend
I have created an model class, Expression<T>, that I would like to use as the valueType for a map feature in another EClass.
     * @model keyType="java.lang.String" valueType="com.example.expression.Expression" containment="true"
    public EMap<String, Expression<Boolean>> getBooleanParameters();
When I generate the model, the method signature is changed to:
public EMap<String, Expression> getBooleanParameters();
Does EMF support specifying a generic type for a map valueType?
Re: Generic valueType for EMap [message #1004911 is a reply to message #1004758] Thu, 24 January 2013 05:29 Go to previous messageGo to next message
Jason,
In Xcore you'd express that like this:
package com.example.expression
class Expression<T>
class StringToBooleanExpressionMapEntry wraps java.util.Map$Entry
String key
refers Expression<Boolean> value
class AnotherClass
contains StringToBooleanExpressionMapEntry[] booleanParameters
It generates this:
* @model
mapType="com.example.expression.StringToBooleanExpressionMapEntry<org.eclipse.emf.ecore.EString,
com.example.expression.Expression<org.eclipse.emf.ecore.EBooleanObject>>"
* @generated
The information about map's type is determined from this in the
generated package.
* @model keyUnique="false" keyDataType="org.eclipse.emf.ecore.EString"
valueType="com.example.expression.Expression<org.eclipse.emf.ecore.EBooleanObject>"
* @generated
EClass getStringToBooleanExpressionMapEntry();
It's very tricky to get the annotations correct, so while it's
definitely possible, there's nothing in the way of error feedback when
you make typos. In Xcore, if you do something wrong, it will tell you
immediately in the editor.
Re: Generic valueType for EMap [message #1005188 is a reply to message #1004911] Thu, 24 January 2013 15:57 Go to previous messageGo to next message
Ed,
It appears that this cannot be done purely with annotated java? If I understand your response correctly, I will first have to create an EClass for the map entry in the ECore editor?
Re: Generic valueType for EMap [message #1005198 is a reply to message #1005188] Thu, 24 January 2013 16:14 Go to previous messageGo to next message
Jason,
No, it can if you get the annotations right. It's certainly expressible
in Ecore and I did check that the model code generated from the Xcore
has @model annotations that can be used as input for creation a model
from annotated Java and I showed you what those annotations look like.
On 24/01/2013 4:57 PM, Jason Roberts wrote:
> Ed,
No, but when it's a big battle to get it right with annotations, it
might be easier to do it in the Ecore editor, let EMF generate the right
annotations (be sure to delete the methods and the package interface so
EMF generates them fully), and then continue from there.
Re: Generic valueType for EMap [message #1005222 is a reply to message #1005198] Thu, 24 January 2013 17:09 Go to previous messageGo to next message
Thanks Ed, you are the man. It works now. The mapType javadoc annotation was so long that my formatter was splitting up the lines which was causing problems when reloading the genmodel.
Re: Generic valueType for EMap [message #1404814 is a reply to message #1004911] Tue, 05 August 2014 23:50 Go to previous messageGo to next message
Jack Greenfield is currently offline Jack GreenfieldFriend
That's a nice feature. However, if it hadn't been for this nice forum post, I would not have known about it. Despite searching fairly carefully for documentation on Xcore, other than the wiki page, which is just a quick overview, I haven't found any. Please tell me I've just looked in the wrong places, and point me to the documentation.
Thanks.
Re: Generic valueType for EMap [message #1404886 is a reply to message #1404814] Wed, 06 August 2014 04:36 Go to previous messageGo to next message
Jack,
Sorry, there's no hidden documentation.
> Thanks.
Re: Generic valueType for EMap [message #1405077 is a reply to message #1404886] Wed, 06 August 2014 14:20 Go to previous message
Thanks for fast reply, Ed. I wonder what other powerful features lie undocumented within Xcore...
Previous Topic:EMF Maven archetype?
Next Topic:return all objects which reference a given one
Current Time: Sat Jul 22 08:56:05 GMT 2017
Powered by FUDForum. Page generated in 0.05499 seconds
