Home » Eclipse Projects » Hudson » package org.hudsonci.maven.plugin.builder does not exist(Extracting build command from a project)
icon9.gif  package org.hudsonci.maven.plugin.builder does not exist [message #1004945] Thu, 24 January 2013 02:36 Go to next message
Lionel Giavelli is currently offline Lionel Giavelli
I'm writing a plugin for Hudson in which I have a need to extract the SCM and Build commands.
I seem to be able to get the data I need from
build.getProject().getScm()
build.getProject().getBuilders()
But I need to convert each object to their native type.
I'm failing to find correct dependency and compile fail with
import org.hudsonci.maven.plugin.builder.MavenBuilder;
Thanks for any suggestion.
Lionel
Re: package org.hudsonci.maven.plugin.builder does not exist [message #1005207 is a reply to message #1004945] Thu, 24 January 2013 11:32 Go to previous message
Winston Prakash is currently offline Winston Prakash
Hi Lionel, please contact me directly at winston . prakash @ gmail . com. I will help you to write the plugin
Winston Prakash
Eclipse Hudson team
Previous Topic:[Solved] Configure job loading screen hangs. Groovy plugin exception.
Next Topic:3.0 Usage
Current Time: Sun May 19 07:34:40 EDT 2013
Powered by FUDForum. Page generated in 0.01600 seconds
