Home » Newcomers » Newcomers » Adding a Glassfish Server in Eclipse Juno Runtime Environment(Problem creating a Glassfish server for my runtime environment in Eclipse Juno. )
Adding a Glassfish Server in Eclipse Juno Runtime Environment [message #1004808] Wed, 23 January 2013 17:48 Go to next message
Nathan Lessani is currently offline Nathan Lessani
I'm having a problem creating a Glassfish server for my runtime environment in Eclipse Juno.
I've installed Eclipse Juno Release 1, & Glassfish 3.2.1 separately. I then installed the Oracle Enterprise Pack for Eclipse which includes the Oracle Glassfish Server Tools from the Eclipse Marketplace. I've verified that it's listed in the Installed Software list in Eclipse.
However, when I try to add a new server, I don't see an option for Glassfish!?
I don't know if I still need to download/add a separate plug-in or server adapter in Eclipse for Glassfish!?
I searched and found a plug-in for Eclipse Helios. But Eclipse Juno gets stuck in the middle of installing it forever!
Any help to shed some light in this issue would be greatly appreciated.
Re: Adding a Glassfish Server in Eclipse Juno Runtime Environment [message #1005185 is a reply to message #1004808] Thu, 24 January 2013 10:41 Go to previous message
Russell Bateman is currently offline Russell Bateman
> Glassfish!?
This is the newcomers' forum; you're asking an Eclipse web tools
platform question. Except that the Eclipse WTP forum is server-agnostic,
but someone there will likely be better able to help you.
The easiest way is to download and use Eclipse IDE for Java EE
Developers (no matter what version, Helio -> Juno all work great).
Previous Topic:Eclipse RCP Menu: Show View Ctrl+F10 is not Enabled
Next Topic:Standalone Help
Current Time: Fri May 24 05:53:57 EDT 2013
Powered by FUDForum. Page generated in 0.01805 seconds
