Home » Eclipse Projects » Remote Application Platform (RAP) » Vertical alignment of Text widgets in RAP vs SWT(How to set vertical Text alignment in RAP)
Vertical alignment of Text widgets in RAP vs SWT [message #997458] Mon, 07 January 2013 10:51 Go to next message
John Gymer is currently offline John Gymer
Member
Does anyone know how to set the vertical alignment of Text in RAP?
In SWT the default behaviour is to align the text entered with the TOP of the entry field, but in RAP the default behaviour is to vertically CENTRE it in the control. For example:
in SWT it is top-aligned:
index.php/fa/12893/0/
but in RAP it is vertically centered:
index.php/fa/12894/0/
Is it possible to change this alignment:
1) programatically?
2) with STYLE on creation of the Text object?
3) with CSS?
Thanks, John
Just because you can doesn't mean you should
Re: Vertical alignment of Text widgets in RAP vs SWT [message #997631 is a reply to message #997458] Tue, 08 January 2013 02:38 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan Furnadjiev
Hi John,
this is a SINGLE Text widget with a custom height. Just checked with SWT
Controls Demo and you are absolutely right - in SWT it is top aligned,
in RAP - center. Please open a bugzilla about this difference.
Ivan
On 1/7/2013 5:51 PM, John Gymer wrote:
> Hello,
> 1) programatically?
> 3) with CSS?
> Thanks, John
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Vertical alignment of Text widgets in RAP vs SWT [message #997632 is a reply to message #997631] Tue, 08 January 2013 04:34 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf Sternberg
This behavior is platform-dependent. In GTK it's vertically centered,
see attached screenshot. The cursor is stretched over the entire height
of the widget. I'd say that this is clearly not a useful application for
a single-line text field. Maybe you want to use a Text with SWT.MULTI?
Ralf
Ralf Sternberg
Re: Vertical alignment of Text widgets in RAP vs SWT [message #1005038 is a reply to message #997632] Thu, 24 January 2013 06:11 Go to previous message
Member
Have resolved this by placing the Text inside an intermediate Composite and using a GridLayout on the Composite to get the Text at the top of the Composite. Works a treat!
Previous Topic:How to do a blocking, in-line refresh of shell in RAP
Next Topic:RWT.getApplicationContext() in non-UI thread
Current Time: Fri May 24 16:12:29 EDT 2013
Powered by FUDForum. Page generated in 0.02698 seconds
