Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Disable generation of ModelFactory and ModelPackage(Need a way to disable generation of additional classes without having to use orm-annotationmodel.)
Disable generation of ModelFactory and ModelPackage [message #1004531] Wed, 23 January 2013 07:10 Go to next message
Pradeep Badiger is currently offline Pradeep Badiger
Member
Is there a way to skip generation of additional classes when texo is triggered for code generation without having to set the "Add Runtime Model Behavior" in the orm-annotationmodel?
thanks,
Pradeep V.B.
Re: Disable generation of ModelFactory and ModelPackage [message #1004537 is a reply to message #1004531] Wed, 23 January 2013 07:22 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Pradeep,
How are you generating code, through a build or directly by programmatically calling the generator?
gr. Martin
On 01/23/2013 01:10 PM, Pradeep Badiger wrote:
> thanks,
> Pradeep V.B.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Disable generation of ModelFactory and ModelPackage [message #1004538 is a reply to message #1004537] Wed, 23 January 2013 07:26 Go to previous messageGo to next message
Member
Martin,
I am generating it through build system.
thanks,
Pradeep V.B.
Re: Disable generation of ModelFactory and ModelPackage [message #1004782 is a reply to message #1004538] Wed, 23 January 2013 16:32 Go to previous messageGo to next message
Hi Pradeep,
The annotations model is the only way currently to get this done...
But you can set this property at runtime before actually generating the source code. You have to write custom generation
code to do the generation.
For examples on how to do custom generation logic:
http://git.eclipse.org/c/texo/org.eclipse.emf.texo.git/tree/tests/org.eclipse.emf.texo.modelgenerator.test/src/org/eclipse/emf/texo/modelgenerator/test/EclipseModelGeneratorTest.java#n147
To programmatically set this option do something like this:
for (EPackage ePackage : ePackages) {
final EPackageModelGenAnnotation ePackageModelGenAnnotation = (EPackageModelGenAnnotation)
modelController.getAnnotationManager()
.getAnnotation(ePackage, ModelcodegeneratorPackage.eINSTANCE.getEPackageModelGenAnnotation());
ePackageModelGenAnnotation.setAddRuntimeModelBehavior(false);
gr. Martin
On 01/23/2013 01:26 PM, Pradeep Badiger wrote:
> Martin,
> thanks,
> Pradeep V.B.
The Netherlands
Re: Disable generation of ModelFactory and ModelPackage [message #1004989 is a reply to message #1004782] Thu, 24 January 2013 04:15 Go to previous message
Member
Perfect!!!
thanks Martin Smile
regards,
Pradeep V.B.
Previous Topic:Deletion of existing classes in same package
Next Topic:Call for Submissions: Modeling Symposium EclipseCon North America 2013
Current Time: Mon May 20 05:05:38 EDT 2013
Powered by FUDForum. Page generated in 0.01949 seconds
