Home » Modeling » Compare » EMF Compare bugzilla change
EMF Compare bugzilla change [message #1004610] Wed, 23 January 2013 09:45
Laurent Goubet is currently offline Laurent Goubet
Hi all,
We've changed the way EMF Compare behaves on the Eclipse bugzilla. Instead of being a Component of EMF, EMF Compare is now a full-fledged product.
In order to raise a bug against EMF Compare from the bugzilla home page :
  • Hit the File a Bug button,
  • Select the Modeling category, and finally
  • Select the EMF.Compare product.
(Alternatively, you could also follow this direct link.)
Thanks for your involvement.
Laurent Goubet
Obeo
[Updated on: Wed, 23 January 2013 09:47]
Report message to a moderator
Previous Topic:EMF Compare models containing "Non-Model Intermediary View Objects"
Next Topic:Using EMF Compare to Compare Other Files
Current Time: Tue May 28 10:30:36 EDT 2013
Powered by FUDForum. Page generated in 0.05241 seconds
