Home » Eclipse Projects » NatTable » Row selection on cell click
Row selection on cell click [message #1004436] Wed, 23 January 2013 03:28 Go to next message
M Prieto is currently offline M Prieto
Hi there!
I'm trying to implement following behavior on the NatTable:
If a user clicks on a rowheader the full row gets selected (nothing special)
If a user clicks on a cell the full row gets selected (special case)
I've tried everything like implementing an own SelectionCommandHandler,
SelectionLayer, etc. how could I get that functionality to work?
Thanks in advance!
Re: Row selection on cell click [message #1004582 is a reply to message #1004436] Wed, 23 January 2013 08:57 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk Fauth
that's not a special case. Just use the RowSelectionModel instead of the default SelectionModel. You can see how this works in the Selection_events example:
selectionLayer.setSelectionModel(new RowSelectionModel<RowDataFixture>(selectionLayer, gridLayer.getBodyDataProvider(), new IRowIdAccessor<RowDataFixture>() {
	public Serializable getRowId(RowDataFixture rowObject) {
		return rowObject.getSecurity_id();
Greez,
Dirk
Re: Row selection on cell click [message #1004587 is a reply to message #1004582] Wed, 23 January 2013 09:00 Go to previous messageGo to next message
Hi!
Thank you for your reply. I already tried that but the problem is that with that RowSelectionModel when I click on a column all rows get selected even when I don't allow multiple selection.
Best Regards.
Re: Row selection on cell click [message #1004592 is a reply to message #1004587] Wed, 23 January 2013 09:08 Go to previous messageGo to next message
Did you implement the getRowId() correctly? This is needed to identify the row to select by model.
Or do you mean on clicking the column header all rows get selected? Well this is because on clicking at the column header, the default behaviour is to select every cell of that column. And with using the RowSelectionModel of course all rows get selected. If you want to avoid this, you need to disable the selection behaviour on clicking the column header. This can be done by overriding and modifying the DefaultSelectionBindings.configureColumnHeaderMouseClickBindings() method.
Re: Row selection on cell click [message #1004595 is a reply to message #1004592] Wed, 23 January 2013 09:09 Go to previous messageGo to next message
Ok, great! The problem may be on the header behavior...I will give that a try.
Thx again.
[Updated on: Wed, 23 January 2013 09:10]
Report message to a moderator
Re: Row selection on cell click [message #1005071 is a reply to message #1004582] Thu, 24 January 2013 07:22 Go to previous messageGo to next message
Hi!
I have tested after overriding the configureColumnHeaderMouseClickBindings method
and it still selects all rows when I click on the header even if in the model I set multipleSelectionAllowed = false.
Is this a by design so or may it be a bug?
[Updated on: Thu, 24 January 2013 07:23]
Re: Row selection on cell click [message #1005121 is a reply to message #1005071] Thu, 24 January 2013 09:12 Go to previous message
How did you override configureColumnHeaderMouseClickBindings()?
I tried this for the Selection_events example by adding this to the RowOnlySelectionBindings (which override DefaultSelectionBindings) and there is nothing selected if I click on the column header:
protected void configureColumnHeaderMouseClickBindings(UiBindingRegistry uiBindingRegistry) {
	//do nothing
So I can't see what the issue is in your case.
Greez,
Dirk
Previous Topic:Unregister Keybindings
Next Topic:Invert axis in nattable
Current Time: Fri May 24 11:12:50 EDT 2013
Powered by FUDForum. Page generated in 0.27543 seconds
