Home » Modeling » XSD » Change Ecore model which has been derived from XML schema
Change Ecore model which has been derived from XML schema [message #1004593] Wed, 23 January 2013 09:08
Florian W. is currently offline Florian W.
Following an advice from Ed Merks, I added an additional reference to an Ecore model which has been derived from an XML schema. Unfortunately, the manual changes to the Ecore model are overwritten every time I reload the XML schema. So I have to apply all manual changes again. Is there a more elegant way to add modifications to an imported Ecore model?
Previous Topic:Problem loading XSD file
Next Topic:XML Editor Validation in RCP
Current Time: Fri May 24 23:06:31 EDT 2013
Powered by FUDForum. Page generated in 0.01662 seconds
