Home » Modeling » TMF (Xtext) » Null pointer through customizing outline view
Null pointer through customizing outline view [message #1004520] Wed, 23 January 2013 06:43 Go to next message
Phil H is currently offline Phil H
Member
according to the documentation, I tried to style my outline view. Where it works for the rule ConfiguratioName (see below), I got the following Errormessage by modeling a Model or Parameters: "'Refreshing outline' has encountered a problem. Error refreshing outline" ( Error stack). When I ignore this error and model on, the element will be shown in the outline view in the defined styled way.
Here are my Grammar Rules:
Element:
	(name=ConfigurationName) &
	(model=Model) &
	(paramaters=Parameters)? &
ConfigurationName:
	'name:' configurationname=ID
Model:
	'modelfile:' modelfile=ModelFile
ModelFile:
	(ABSOLUTE_FILEPATH | RELATIVE_FILEPATH)
Parameters:
	'parameters' '{'
		(parameterdesc += ParameterDesc)+
ParameterDesc:
	datatype=[DataType] name=ID value=Value
Here are my text(modelElement) methods:
public Object _text(ConfigurationName cname) {
		return new StyledString(
				cname.getConfigurationname(),
				stylerFactory		.createXtextStyleAdapterStyler(getCnTextStyle()));
	protected TextStyle getCnTextStyle() {
		TextStyle textStyle = new TextStyle();
		textStyle.setBackgroundColor(new RGB(219, 219, 219));
		return textStyle;
public Object _text(Model model) {
		System.out.println(model.getModelfile());
		return new StyledString(model.getModelfile(),				stylerFactory.createXtextStyleAdapterStyler(getModelStyle()));
public Object _text(ParameterDesc param) {
		return new StyledString(param.getName(),
				stylerFactory					.createXtextStyleAdapterStyler(getInterfaceStyle()));
Re: Null pointer through customizing outline view [message #1004534 is a reply to message #1004520] Wed, 23 January 2013 07:13 Go to previous message
Christian Dietrich is currently offline Christian Dietrich
Hi since you enter first the reference and then the name what about a
classical null check on get name?
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Previous Topic:Rename shifts from expectation
Next Topic:Problem running xtext workflow in Plugin Environment
Current Time: Sun May 19 20:17:47 EDT 2013
Powered by FUDForum. Page generated in 0.02038 seconds
