| Re: linking lifeline to its corresponding class [message #1004186 is a reply to message #1004120] |
Tue, 22 January 2013 13:53   |
Christian W. Damus Messages: 551 Registered: July 2009 |
Hi, Mohamed,
A Lifeline represents a ConnectableElement, usually a Property of some
classifier. This is why the editor gives you a list of properties to
choose from, not classes.
So, in the context classifier of your interaction, there should be a
property typed by the Class that you want your lifeline to represent.
As discussed recently in the Papyrus forum, a Collaboration is a
convenient classifier in which to model the interactions of your
classes by way of owned properties serving as "collaboration roles"
that your lifelines can represent. See the "Sequence Diagrams" thread
in that forum, started on 11 January.
HTH,
Christian
On 2013-01-22 16:05:16 +0000, Mohamed Mussa said:
> HI everybody,
> I have Package with UML Classes and Interactions descibing some
> scenarios of these classes.
> How can I associate a lifeline in Sequence diagram to a class in the
> class diagram?
> There is field "Represents" in the properties view of the lifeline but
> it lists the names of the association between the classes not the
> classes!
> Thanks in advance..
> Mohamed
FUDForum. Page generated in 0.01687 seconds
