Home » Eclipse Projects » BIRT » Adding a Chart Type To BIRT - Error while Importing XML Schema
Adding a Chart Type To BIRT - Error while Importing XML Schema [message #1003709] Mon, 21 January 2013 16:04 Go to next message
Samo Gb is currently offline Samo Gb
Member
Hi all,
I'm working on the following example:
Adding a Chart Type To BIRT(devShare)
When I try to import the XML Schema I get following error:
index.php/fa/13045/0/
Samet
Re: Adding a Chart Type To BIRT - Error while Importing XML Schema [message #1004274 is a reply to message #1003709] Tue, 22 January 2013 17:39 Go to previous messageGo to next message
Kristopher Clark is currently offline Kristopher Clark
You need to get the xsd files from the chart plugin. What I did was downloaded the birt source from github. Then I imported org.eclipse.birt.chart.engine as an existing project. After that you will be able to add segment.xsd without any errors.
Re: Adding a Chart Type To BIRT - Error while Importing XML Schema [message #1005446 is a reply to message #1003709] Fri, 25 January 2013 08:26 Go to previous message
Member
Hi Kristopher,
thank you for hreplying.
I'll try it.
Samet
Previous Topic:Safari 6.0 and Birt support
Next Topic:How to fixe a header row in a CrossTab?
Current Time: Fri May 24 03:42:45 EDT 2013
Powered by FUDForum. Page generated in 0.01738 seconds
