| Is Babel 0.10.1 really compatible with Eclipse 3.8 and/or Tycho? [message #1004239] |
Tue, 22 January 2013 16:21  |
Eric Rizzo Messages: 2011 Registered: July 2009 |
I'm building a product based on Eclipse 3.8. The product compiles fine in Eclipse IDEs and with our newly-constructed Tycho build. However, when I add the Babel repository () to our target platform, Tycho complains with strange compilation errors realting to not finding SWT classes. The exact same target platform applied to Eclipse 3.8 SDK workspaces produces no compilation errors.
Here is some of what Tycho spits out:
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-compiler-plugin:0.16.0:compile (default-compile) on project com.emc.xcp.common.ui: Compilation failure: Compilation failure:
[ERROR] F:\P4_Int\depot\Platform\XCPBuilder\Int\int_XCPBLD_2.0\staging\app\bundles\com.emc.xcp.common.ui\src\com\emc\xcp\common\ui\function\FunctionPalette.java:[0,0]
[ERROR] package com.emc.xcp.common.ui.function;
[ERROR] ^
[ERROR] The type org.eclipse.swt.events.KeyEvent cannot be resolved. It is indirectly referenced from required .class files
[ERROR] F:\P4_Int\depot\Platform\XCPBuilder\Int\int_XCPBLD_2.0\staging\app\bundles\com.emc.xcp.common.ui\src\com\emc\xcp\common\ui\function\FunctionPalette.java:[20,0]
[ERROR] public class FunctionPalette extends AbstractTreePalette {
[ERROR] ^^^^^^^^^^^^^^^
[ERROR] The hierarchy of the type FunctionPalette is inconsistent
I noticed that all the Babel bundles are versioned 4.2.0, so I wondered if they are actually tested against Eclipse 3.8 plugins. I have confirmed (twice) that simply removing the Babel bundles from the target platform restores the build to success, so I'm pretty confused about how including Babel bundles could trigger compile errors referring to SWT.
Any ideas?
Eric
[Updated on: Tue, 22 January 2013 18:11] Report message to a moderator
FUDForum. Page generated in 0.01583 seconds
