Home » Eclipse Projects » Hudson » Hudson unable to send emails
Hudson unable to send emails [message #879092] Wed, 30 May 2012 09:55 Go to next message
kiran gunda is currently offline kiran gunda
I download Hudson M2 WAR file and configured a job. In the 'Manage Hudson' -> 'Configure System' -> Email Notification section -> 'Test Configuration by sending e-mail to System Administration' works fine, I am able to receive email.
But when I configured a job and job is completed with unit tests failed (Build Failed), then I see the following SMTP authentication error and I don't receive emails. When 'Test Configuration by email' button works fine, why it is unable to send email when job fails? Basically my question, why it is trying to authenticate? I did not enable SMTP authentication. Test Configuration works fine but not when job is completed.. any ideas?
ERROR: 535 5.7.3 Authentication unsuccessful
javax.mail.AuthenticationFailedException: 535 5.7.3 Authentication unsuccessful
	at com.sun.mail.smtp.SMTPTransport$Authenticator.authenticate(SMTPTransport.java:809)
	at com.sun.mail.smtp.SMTPTransport.authenticate(SMTPTransport.java:752)
	at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:669)
	at javax.mail.Service.connect(Service.java:295)
	at hudson.tasks.Mailer$DescriptorImpl.send(Mailer.java:491)
	at hudson.tasks.Mailer$DescriptorImpl.send(Mailer.java:464)
	at hudson.tasks.MailSender.execute(MailSender.java:93)
	at hudson.tasks.Mailer.perform(Mailer.java:115)
[Updated on: Wed, 30 May 2012 10:12]
Report message to a moderator
Re: Hudson unable to send emails [message #879177 is a reply to message #879092] Wed, 30 May 2012 13:10 Go to previous messageGo to next message
This seems a bug in 3.0.0 M2 code, when I downgraded to 2.2 this feature worked fine.
Re: Hudson unable to send emails [message #899175 is a reply to message #879177] Mon, 30 July 2012 16:42 Go to previous messageGo to next message
Mario Charest is currently offline Mario Charest
Hum funny, it was working for me with M2 but now with M3 (I did a complete reinstall) I have the same problem as the OP.
Re: Hudson unable to send emails [message #900070 is a reply to message #899175] Fri, 03 August 2012 15:36 Go to previous messageGo to next message
Steve Christou is currently offline Steve Christou
Are you using any email plugins like Email-ext plugin?
 * @author Steven Christou
 * @dev    Hudson-ci
Re: Hudson unable to send emails [message #977797 is a reply to message #879092] Fri, 09 November 2012 10:33 Go to previous messageGo to next message
Sebastiaan Hobers is currently offline Sebastiaan Hobers
I have the same issue on 3.0.0 RC2.
Any idea if this issue is solved in the RC4?
Re: Hudson unable to send emails [message #978076 is a reply to message #977797] Fri, 09 November 2012 15:39 Go to previous messageGo to next message
I can take a look at this issue. What email smtp server are you using?
Thinking this over... I'm thing that could be the issue is the incomplete id, example for Gmail instead of using just the username you must do username@gmail.com
 * @dev    Hudson-ci
[Updated on: Fri, 09 November 2012 15:45]
Re: Hudson unable to send emails [message #1004236 is a reply to message #978076] Tue, 22 January 2013 16:12 Go to previous messageGo to next message
Jesper Tejlgaard is currently offline Jesper Tejlgaard
I've just upgraded from Hudson 2.2.1 to Hudson 3.0.0 and is now experiencing this problem. Any solutions to the problem or hints to why it happens?
[Updated on: Wed, 23 January 2013 07:27]
Re: Hudson unable to send emails [message #1004249 is a reply to message #1004236] Tue, 22 January 2013 16:34 Go to previous messageGo to next message
I believe it has something to do with the javax-mail library in hudson-core. We upgraded from 1.4 to 1.4.4.
 * @dev    Hudson-ci
Re: Hudson unable to send emails [message #1004551 is a reply to message #1004249] Wed, 23 January 2013 07:47 Go to previous messageGo to next message
My stack trace is actually different (see http://www.eclipse.org/forums/index.php/m/1004550/#msg_1004550), but it might still be related to the javax.mail upgrade.
Re: Hudson unable to send emails [message #1006649 is a reply to message #1004551] Fri, 01 February 2013 05:26 Go to previous messageGo to next message
luke biddell is currently offline luke biddell
Just to confirm, I've cracked open the Hudson war and replaced mail 1.4.4 with mail 1.4 and email is now being sent.
Re: Hudson unable to send emails [message #1006725 is a reply to message #879092] Fri, 01 February 2013 10:38 Go to previous messageGo to next message
Leon Qin is currently offline Leon Qin
I have the same issue.
I looked into the source code, and found something wrong. (hudson.tasks.Mailer)
If the SMTP authentication is not enabled,
the sendTestMail function will send the mail with null username and null password.
but the function of sending normal notifications, will send the mail with null username and empty password. This cause our issue.
I tried to use my modified version in my own environment. The problem has gone.
Hope this issue could be fixed in the main stream.
Re: Hudson unable to send emails [message #1007671 is a reply to message #1006725] Wed, 06 February 2013 18:23 Go to previous messageGo to next message
Winston Prakash is currently offline Winston Prakash
Hi Leon, could you please submit your patch to the core via Gerrit
The details about submitting patch can be found here
http://wiki.eclipse.org/Hudson-ci/development#Submitting_a_Patch_for_Non-Committers
(repeating here to get your attention Smile )
Winston Prakash
Eclipse Hudson team
Re: Hudson unable to send emails [message #1014994 is a reply to message #1007671] Wed, 27 February 2013 02:39 Go to previous messageGo to next message
Tang Shi-Ming is currently offline Tang Shi-Ming
I don't see this with Hudson ver 3.0.0 Bundled
Re: Hudson unable to send emails [message #1016107 is a reply to message #1014994] Tue, 05 March 2013 00:40 Go to previous message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=399631
Winston Prakash
Eclipse Hudson team
Previous Topic:Python API URL is responding with 404 Not Found
Next Topic:Next Community Meeting
Current Time: Sat May 18 09:33:55 EDT 2013
Powered by FUDForum. Page generated in 0.02238 seconds
