| Initial artifact vs plan deployed in pickup [message #1002421] |
Fri, 18 January 2013 09:46  |
Lorie Pisicchio Messages: 44 Registered: October 2010 |
Member |
Hi all,
I am observing a behavior I have never seen before.
We are building a platform on top of Virgo 3.5. The platform is composed of a set of bundles, organized in plans. To make sure that the platform is ready when our users deploy their application (by placing their bundles in pickup), we are starting our platform plans into initialArtifacts (by editing user region properties file).
We are using JPA for automatic generation of persistence entities.
One of my plans won't deploy when started in initialArtifacts. It fails with the following error.
[2013-01-18 15:37:23.536] region-dm-1 <AG0000E> Application context creation failure for bundle 'my-bundle' version '3.1.0.BUILD-SNAPSHOT'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sendingTask' defined in URL [bundleentry://231.fwk1587097459/META-INF/spring/context.xml]: Cannot resolve reference to bean 'campaignService' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'campaignService' defined in URL [bundleentry://231.fwk1587097459/META-INF/spring/context.xml]: Cannot resolve reference to bean 'campaignRepository' while setting bean property 'repository'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'campaignRepository': FactoryBean threw exception on object creation; nested exception is java.lang.IllegalArgumentException: interface com.anything.MyInterface is not visible from class loader
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:605)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:925)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:60)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:325)
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:290)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137)
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'campaignService' defined in URL [bundleentry://231.fwk1587097459/META-INF/spring/context.xml]: Cannot resolve reference to bean 'campaignRepository' while setting bean property 'repository'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'campaignRepository': FactoryBean threw exception on object creation; nested exception is java.lang.IllegalArgumentException: interface com.anything.MyInterface is not visible from class loader
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1360)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1118)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323)
... 22 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'campaignRepository': FactoryBean threw exception on object creation; nested exception is java.lang.IllegalArgumentException: interface com.anything.MyInterface is not visible from class loader
at org.springframework.beans.factory.support.FactoryBeanRegistrySupport.doGetObjectFromFactoryBean(FactoryBeanRegistrySupport.java:149)
at org.springframework.beans.factory.support.FactoryBeanRegistrySupport.getObjectFromFactoryBean(FactoryBeanRegistrySupport.java:102)
at org.springframework.beans.factory.support.AbstractBeanFactory.getObjectForBeanInstance(AbstractBeanFactory.java:1442)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:248)
... 32 common frames omitted
Caused by: java.lang.IllegalArgumentException: interface com.anything.MyInterface is not visible from class loader
at java.lang.reflect.Proxy.getProxyClass(Proxy.java:373)
at java.lang.reflect.Proxy.newProxyInstance(Proxy.java:601)
at org.springframework.aop.framework.JdkDynamicAopProxy.getProxy(JdkDynamicAopProxy.java:117)
at org.springframework.aop.framework.JdkDynamicAopProxy.getProxy(JdkDynamicAopProxy.java:108)
at org.springframework.aop.framework.ProxyFactory.getProxy(ProxyFactory.java:98)
at org.springframework.data.repository.core.support.RepositoryFactorySupport.getRepository(RepositoryFactorySupport.java:150)
at org.springframework.data.repository.core.support.RepositoryFactoryBeanSupport.getObject(RepositoryFactoryBeanSupport.java:125)
at org.springframework.data.repository.core.support.RepositoryFactoryBeanSupport.getObject(RepositoryFactoryBeanSupport.java:41)
at org.springframework.beans.factory.support.FactoryBeanRegistrySupport.doGetObjectFromFactoryBean(FactoryBeanRegistrySupport.java:142)
... 37 common frames omitted
com.anything package is declared in the bundle my-bundle (the one that fails to deploy because it cannot load the interface). This package is the base package for jpa repositories.
If I remove this plan from initialArtifacts, and deploy it into the pickup directory, then it will install correctly.
Someone could explain me what is the difference between the two exposed cases? In my understanding, initialArtifacts were bundles deployed in user region, just as bundles deployed into pickup. The only difference I'm aware of is that those bundles are deployed before any others.
Any help will be appreciated.
Thanx in advance.
[Updated on: Fri, 18 January 2013 10:28] Report message to a moderator
FUDForum. Page generated in 0.01632 seconds
