Home » Language IDEs » CDT » Eclipse CDT Juno, C++11, GCC 4.8 on OS X Lion and MLion
Eclipse CDT Juno, C++11, GCC 4.8 on OS X Lion and MLion [message #923059] Tue, 25 September 2012 11:13 Go to next message
Andrew Tchieu is currently offline Andrew Tchieu
Hi everyone, i'm having extreme difficulty with getting Eclipse to recognize C++11 syntax for a Makefile project.
I've done what was recommended here, but it doesn't work out for me: http://www.eclipse.org/forums/index.php/mv/msg/373462/909018/#msg_909018
My current configuration is: Eclipse CDT Juno, C++11, GCC 4.8 (from HPC OS X) on OS X Lion, i've installed GCC 4.8 to /usr/local/
Does anyone have any advice on this?
Re: Eclipse CDT Juno, C++11, GCC 4.8 on OS X Lion and MLion [message #1004048 is a reply to message #923059] Tue, 22 January 2013 08:51 Go to previous message
x t is currently offline x t
scrupulousabstractions.tumblr.com/post/36441490955/eclipse-mingw-builds
I have tested on Windows platform, and it works! C++11 new key words and syntax are correctly recognized and accepted. Hopefully it will help you.
Select the Properties window from the Project menu. Go to the Settings sub-menu under C/C++ Build.
Select [ All configurations ] at the top, and add the option -std=c++11 to the field Other flags Under both GCC C++ Compiler/Miscellaneous and GCC C++ Linker/Miscellaneous.
Under C/C++ General (again in project properties), find the Preprocessor Include Path and go to the Providers Tab. Deselect all except CDT GCC Builtin Compiler Settings. Then untag Share settings entries ... . Add the option -std=c++11 to the text box called Command to get compiler specs.
Go to paths and symbols (again under Under C/C++ General). Selects the Symbols tab, click restore defaults, and then click Apply.
Previous Topic:Unresolved References
Next Topic:Resource Custom Build Step corrupts Project
Current Time: Sun May 26 01:59:31 EDT 2013
Powered by FUDForum. Page generated in 0.01450 seconds
