Home » Modeling » ATL » How to delete a model element of rule ?
How to delete a model element of rule ? [message #1003957] Tue, 22 January 2013 05:23 Go to next message
Nicolas Fauvergue is currently offline Nicolas Fauvergue
Hi all,
I am developing an ATL plug-in and i have a problem.
This is the following :
In fact i create an output model element from an input model element and in some cases, this output element musn't be created.
For the moment, i succeed to recognize if i have to delete this element or not by this following implementation :
helper def : lastNode : tc463!NodeType = OclUndefined;
rule Step{
	from
		step : tc50!Step
	to
		node : tc463!NodeType(
			transition <- transition463
		transition463 : tc463!TransitionType(
			x <- step50.x;
	do{
                if(thisModule.lastNode.oclIsUndefined()){
			thisModule.lastNode <- node463;
		}else{
			if(thisModule.lastNode.id = node463.id){
				thisModule.lastNode.transition <- node463.transition;
				--I have to delete node463 here
			}else{
I tryed to delete this element by affect "OclUndefined" to this element but it didin't work.
Have you an idea to make this action ?
Thank you a lot in advance.
Nicolas
[Updated on: Tue, 22 January 2013 09:12]
Report message to a moderator
Re: How to delete a model element of rule ? [message #1004088 is a reply to message #1003957] Tue, 22 January 2013 09:57 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
In regular transformations (i.e. when the input and output metamodels are different), you don't need to "delete" elements as you are only creating new elements into the target model (initially empty).
In your current example, you should probably add a guard to the input pattern of your rule in order to match it (and thus create the corresponding model element) only when required.
I encourage to take a look to the ATL user guide to get more insights on this.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: How to delete a model element of rule ? [message #1004130 is a reply to message #1004088] Tue, 22 January 2013 11:19 Go to previous message
Thank you.
In fact, i just have to reorganize my document and use lazy rulse to have a better solution.
Nicolas
Previous Topic:The class 'VisitableCS' is not a valid classifier
Next Topic:Finanzverwaltung von Vereinen
Current Time: Thu May 23 07:41:20 EDT 2013
Powered by FUDForum. Page generated in 0.01622 seconds
