Home » Eclipse Projects » EclipseLink » TABLE_PER_TENANT(Anyone implemented TABLE_PER_TENANT strategy with Eclipselink)
TABLE_PER_TENANT [message #1003831] Mon, 21 January 2013 23:38 Go to next message
sys alleys is currently offline sys alleys
Anyone implemented TABLE_PER_TENANT strategy with Eclipselink coz I could not
find a basic tutorial of how to implement that? Though I tried but it is not working.
thanks in advance
[Updated on: Mon, 21 January 2013 23:39]
Report message to a moderator
Re: TABLE_PER_TENANT [message #1004102 is a reply to message #1003831] Tue, 22 January 2013 10:24 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
What error are you getting, and what version are you using?
There is some examples here,
http://www.eclipse.org/eclipselink/documentation/2.4/solutions/multitenancy003.htm#A1235913
and,
http://www.eclipse.org/eclipselink/documentation/2.4/jpa/extensions/a_multitenant.htm#BABEGBIJ
James : Wiki : Book : Blog
Re: TABLE_PER_TENANT [message #1005707 is a reply to message #1004102] Mon, 28 January 2013 06:04 Go to previous messageGo to next message
Hi ,
thanks for your response. I have gone through your links but there is no clear indication. I put the environments and the code
pls. make a review if it is right but I am getting null pointer exception.
Environment:
Netbeans 7.2 , Glassfish 3.1, EclipseLink, version: Eclipse Persistence Services - 2.4.1.v20121003-ad44345
EJB:: Account.java
@Entity
@Multitenant(MultitenantType.TABLE_PER_TENANT)
@TenantTableDiscriminator(type=TenantTableDiscriminatorType.SCHEMA, contextProperty="eclipselink.mytenant1")
@Table(name = "ACCOUNT")
@XmlRootElement
@NamedQueries({
Stateless:: AccountServices.java
public EntityManager getEMF() {
if (em == null) {
// Non shared EMF
System.out.println("getEMF()-> emf is null");
HashMap properties = new HashMap();
properties.put(PersistenceUnitProperties.TRANSACTION_TYPE, PersistenceUnitTransactionType.JTA.name());
properties.put(PersistenceUnitProperties.MULTITENANT_SHARED_EMF, "false");
properties.put(PersistenceUnitProperties.SESSION_NAME, "non-shared-emf-for-mytenant1");
properties.put(PersistenceUnitProperties.MULTITENANT_PROPERTY_DEFAULT, "mytenant1");
em = Persistence.createEntityManagerFactory("tenantproj-ejbPU").createEntityManager(properties);
return em;
Persistence.xml
<persistence-unit name="tenantproj-ejbPU" transaction-type="JTA">
<jta-data-source>jndi/mytenant1</jta-data-source>
<exclude-unlisted-classes>false</exclude-unlisted-classes>
<properties>
<property name="javax.persistence.jdbc.driver" value="com.mysql.jdbc.Driver" />
<property name="javax.persistence.jdbc.url" value="jdbc:mysql://localhost:3306/mytenant1?zeroDateTimeBehavior=convertToNull" />
<property name="javax.persistence.jdbc.user" value="xxxx" />
<property name="javax.persistence.jdbc.password" value="mysqlxx" />
<property name="eclipselink.multitenant.tenants-share-emf" value="false"/>
<property name="eclipselink.session-name" value="non-shared-emf-for-mytenant1"/>
<property name="eclipselink.tenant-id" value="mytenant1"/>
</properties>
</persistence-unit>
</persistence>
Error
Calling EJB Services->CreateT()
javax.ejb.EJBException
at com.sun.ejb.containers.BaseContainer.processSystemException(BaseContainer.java:5215)
at com.sun.ejb.containers.BaseContainer.completeNewTx(BaseContainer.java:5113)
at com.sun.ejb.containers.BaseContainer.postInvokeTx(BaseContainer.java:4901)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:2045)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:1994)
at com.sun.ejb.containers.EJBObjectInvocationHandler.invoke(EJBObjectInvocationHandler.java:213)
at com.sun.ejb.containers.EJBObjectInvocationHandlerDelegate.invoke(EJBObjectInvocationHandlerDelegate.java:79)
at $Proxy173.createT(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at com.sun.corba.ee.impl.presentation.rmi.ReflectiveTie.dispatchToMethod(ReflectiveTie.java:144)
at com.sun.corba.ee.impl.presentation.rmi.ReflectiveTie._invoke(ReflectiveTie.java:174)
at com.sun.corba.ee.impl.protocol.CorbaServerRequestDispatcherImpl.dispatchToServant(CorbaServerRequestDispatcherImpl.java:528)
at com.sun.corba.ee.impl.protocol.CorbaServerRequestDispatcherImpl.dispatch(CorbaServerRequestDispatcherImpl.java:199)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.handleRequestRequest(CorbaMessageMediatorImpl.java:1624)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.handleRequest(CorbaMessageMediatorImpl.java:1486)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.handleInput(CorbaMessageMediatorImpl.java:990)
at com.sun.corba.ee.impl.protocol.giopmsgheaders.RequestMessage_1_2.callback(RequestMessage_1_2.java:214)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.handleRequest(CorbaMessageMediatorImpl.java:742)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.dispatch(CorbaMessageMediatorImpl.java:539)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.doWork(CorbaMessageMediatorImpl.java:2324)
at com.sun.corba.ee.impl.orbutil.threadpool.ThreadPoolImpl$WorkerThread.performWork(ThreadPoolImpl.java:497)
at com.sun.corba.ee.impl.orbutil.threadpool.ThreadPoolImpl$WorkerThread.run(ThreadPoolImpl.java:540)
Caused by: java.lang.NullPointerException
at org.eclipse.persistence.descriptors.DescriptorEventManager.notifyEJB30Listeners(DescriptorEventManager.java:619)
at org.eclipse.persistence.descriptors.DescriptorEventManager.executeEvent(DescriptorEventManager.java:200)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerNewObjectClone(UnitOfWorkImpl.java:4287)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerNotRegisteredNewObjectForPersist(UnitOfWorkImpl.java:4264)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.registerNotRegisteredNewObjectForPersist(RepeatableWriteUnitOfWork.java:511)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerNewObjectForPersist(UnitOfWorkImpl.java:4206)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.persist(EntityManagerImpl.java:451)
at au.com.std.tenantproj.jee.services.AbstractServices.createT(AbstractServices.java:28)
at au.com.std.tenantproj.jee.services.AccountServices.createT(AccountServices.java:24)
at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:1052)
at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:1124)
at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:5388)
at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:619)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:800)
at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:571)
at org.jboss.weld.ejb.SessionBeanInterceptor.aroundInvoke(SessionBeanInterceptor.java:49)
at sun.reflect.GeneratedMethodAccessor116.invoke(Unknown Source)
at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:861)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doAround(SystemInterceptorProxy.java:162)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundInvoke(SystemInterceptorProxy.java:144)
at sun.reflect.GeneratedMethodAccessor115.invoke(Unknown Source)
at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:370)
at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:5360)
at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:5348)
at com.sun.ejb.containers.EJBObjectInvocationHandler.invoke(EJBObjectInvocationHandler.java:206)
... 19 more
Re: TABLE_PER_TENANT [message #1006048 is a reply to message #1005707] Tue, 29 January 2013 11:01 Go to previous message
The null-pointer seems like the descriptor was not initialized.
It could be an issue with passing the properties to the createEntityManager, try removing this.
Also please try the latest patch, and log a bug if you still get the error, a null-pointer exception should never occur.
Previous Topic:@Inheritante with @OneToOne And @ID - Internal error
Next Topic:EL OSGi EntityManagerFactoryBuilder creates EntityManagerFactory for different DBs wrongly
Current Time: Wed May 22 15:13:12 EDT 2013
Powered by FUDForum. Page generated in 0.04445 seconds
