Home » Eclipse Projects » Rich Client Platform (RCP) » Add specific visual Editor from plugin to E4 RCP Application
icon7.gif  Add specific visual Editor from plugin to E4 RCP Application [message #1003694] Mon, 21 January 2013 15:10
Michael Kornmann is currently offline Michael Kornmann
Hello again !
I am following this tutorial http://dirksmetric.wordpress.com/2012/08/01/tutorial-eclipse-rcp-e4-with-3-x-views-like-project-explorer-properties-etc/ but when i try to open a file with an visual editor that was created by some people from my university i get errors:
org.eclipse.e4.core.di.InjectionException: java.lang.ClassCastException: org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl cannot be cast to org.eclipse.e4.ui.model.application.ui.basic.MTrimElement
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:859)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:839)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:319)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:896)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:630)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:732)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:703)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:697)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:682)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:91)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4291)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:418)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:385)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:579)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:315)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:985)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3079)
	at org.eclipse.ui.internal.WorkbenchPage.access$22(WorkbenchPage.java:3003)
	at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2985)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2981)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2940)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2923)
	at de.uni_mannheim.informatik.swt.models.plm.diagram.part.PLMDiagramEditorUtil.openDiagram(PLMDiagramEditorUtil.java:83)
	at de.uni_mannheim.informatik.swt.models.plm.diagram.part.PLMCreationWizard$1.execute(PLMCreationWizard.java:124)
	at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
	at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
	at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1028)
	at de.uni_mannheim.informatik.swt.models.plm.diagram.part.PLMCreationWizard.performFinish(PLMCreationWizard.java:136)
	at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3554)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3179)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:259)
	at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:279)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:601)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
	at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:500)
	at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at test.rcp.Application.start(Application.java:126)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.ClassCastException: org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl cannot be cast to org.eclipse.e4.ui.model.application.ui.basic.MTrimElement
	at org.eclipse.ui.internal.CoolBarToTrimManager.find(CoolBarToTrimManager.java:266)
	at org.eclipse.ui.internal.EditorActionBars.getToolBarManager(EditorActionBars.java:266)
	at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:168)
	at org.eclipse.gef.ui.actions.ActionBarContributor.init(ActionBarContributor.java:144)
	at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramActionBarContributor.init(DiagramActionBarContributor.java:62)
	at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:146)
	at de.uni_mannheim.informatik.swt.models.plm.diagram.part.PLMDiagramActionBarContributor.init(PLMDiagramActionBarContributor.java:39)
	at org.eclipse.ui.internal.EditorReference.createEditorActionBars(EditorReference.java:405)
	at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:320)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:288)
	... 111 more
!ENTRY de.uni_mannheim.informatik.swt.models.plm.diagram 4 0 2013-01-21 21:07:04.962
!MESSAGE Error creating diagram
!STACK 0
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3095)
Open a text file in the normal text editor works fine. Can someone help me here maybe ?
... 111 more
!STACK 0
Previous Topic:Open a file in the editor from code
Next Topic:Invoking RCP plugin
Current Time: Tue May 21 08:48:12 EDT 2013
Powered by FUDForum. Page generated in 0.01579 seconds
