Home » Eclipse Projects » Eclipse Platform » IDocumentProvider.getAnnotationModel is null
IDocumentProvider.getAnnotationModel is null [message #1003509] Mon, 21 January 2013 06:53 Go to next message
Ralph Gerbig is currently offline Ralph Gerbig
when calling documentProvider.getAnnotationModel(getEditorInput()) returns null. How can I get this method to return an IAnnotationModel. The only way I found was to override the methode of FileDocumentProvider to return a annotation model. Is this the right way to do it?
Ralph
Re: IDocumentProvider.getAnnotationModel is null [message #1003620 is a reply to message #1003509] Mon, 21 January 2013 11:16 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
On 21.01.2013 12:53, Ralph Gerbig wrote:
> Hello,
> way to do it?
Try using TextFileDocumentProvider.
Dani
> Ralph
Re: IDocumentProvider.getAnnotationModel is null [message #1003907 is a reply to message #1003620] Tue, 22 January 2013 03:06 Go to previous messageGo to next message
Hi Dani,
thanks for your reply. FileTextDocumentProvider also returns null. I did take a look at its source code and the implementation of createAnnotationModel could be the reason for it.
 * Creates and returns the annotation model for the given file.
 * @param file the file
 * @return the file's annotation model or <code>null</code> if none
 protected IAnnotationModel createAnnotationModel(IFile file) {
	return null;
Ralph
Re: IDocumentProvider.getAnnotationModel is null [message #1004069 is a reply to message #1003907] Tue, 22 January 2013 09:25 Go to previous messageGo to next message
On 22.01.2013 09:06, Ralph Gerbig wrote:
> Hi Dani,
By default, the annotation model is taken from the file buffer, so it
looks like something is going wrong there. See
org.eclipse.ui.editors.text.TextFileDocumentProvider.createFileInfo(Object)
for a debug entry point.
Dani
> return null;
> Ralph
Re: IDocumentProvider.getAnnotationModel is null [message #1004070 is a reply to message #1004069] Tue, 22 January 2013 09:29 Go to previous messageGo to next message
this is where my problem seems to come from. I do not hava a file for my document. It displays a custom implementation of IEditorInput.
Ralph
Re: IDocumentProvider.getAnnotationModel is null [message #1004087 is a reply to message #1004070] Tue, 22 January 2013 09:55 Go to previous messageGo to next message
On 22.01.2013 15:29, Ralph Gerbig wrote:
OK, in that case you have to create your own document provider (try
whether you can inherit from StorageDocumentProvider otherwise use
AbstractDocumentProvider) and implement #createAnnotationModel(...),
returning a new AnnotationModel();.
Another approach could be to back your data by your own file system
implementation (EFS). That way you could then use the
Dani
> Ralph
Re: IDocumentProvider.getAnnotationModel is null [message #1004652 is a reply to message #1004087] Wed, 23 January 2013 10:44 Go to previous message
Hi Dani,
thank you very much for your excellent support. I did create my own document provider.
Thank you very much!
Ralph
Previous Topic:CVS Password Not Saved with Eclipse 3.4
Next Topic:SIGSEGV error while running eclipse equinox.launcher on HP-UX and JRE6
Current Time: Tue May 21 15:22:07 EDT 2013
Powered by FUDForum. Page generated in 0.01949 seconds
