Home » Newcomers » Newcomers » Else Error (Total newcomer)(Syntax error when trying to use else )
Else Error (Total newcomer) [message #1001149] Wed, 16 January 2013 01:17 Go to next message
Sean Wirth is currently offline Sean Wirth
Hi friends,
I just started taking a intro to java programming course for my major programming requirement and I'm having trouble using "else" when I'm trying to make if statements.
Every time I type in "else" it gives me the error "Syntax error on token, "else," Delete this token"
I've been watching videos and I'm really trying to get a leg up on the class and really get an understanding of java and eclipse because I've always liked the idea of being able to program using java.
Any help would be greatly appreciated!
Re: Else Error (Total newcomer) [message #1001355 is a reply to message #1001149] Wed, 16 January 2013 09:48 Go to previous messageGo to next message
Russell Bateman is currently offline Russell Bateman
On 1/16/2013 6:31 AM, Sean Wirth wrote:
> Hi friends,
First, this is a Java not an Eclipse question. Java questions are better
referred to forums for that purpose, some include javaranch.com,
jguru.com and stackoverflow.com.
Second, it's pretty hard to play compiler for you when you don't submit
any code to look at.
Re: Else Error (Total newcomer) [message #1003613 is a reply to message #1001355] Mon, 21 January 2013 11:03 Go to previous message
David Kerber is currently offline David Kerber
In article <kd6eno$kvs$2@xxxxxxxxe.org>, russ@xxxxxxxx
says...
> > Hi friends,
All that said, you're probably missing some curly braces.
Previous Topic:Using external jar file from eclipse plugin
Next Topic:Hibernate mapping
Current Time: Thu May 23 09:09:14 EDT 2013
Powered by FUDForum. Page generated in 0.01494 seconds
