Home » Eclipse Projects » Remote Application Platform (RAP) » How to change timeout page
How to change timeout page [message #651340] Sat, 29 January 2011 09:43 Go to next message
evol is currently offline evol
I just wonder how can I chage session timeout page. I guess it can be done by preserving "timeoutPage" in widget adapter. But there is a bit of confusion. The code of writeErrorPages method (org.eclipse.swt.internal.widgets.displaykit.DisplayLCA) is seems to always write predefined timeout page and do not use preserved value at all. Is there is some kind of trick that I do not understand or maybe it's just a misprint in variables names?
Here is a code of the method below:
private static void writeErrorPages( final Display display )
    throws IOException
    String timeoutPage = getTimeoutPage();
    IWidgetAdapter adapter = DisplayUtil.getAdapter( display );
    Object newTimeoutPage = adapter.getPreserved( PROP_TIMEOUT_PAGE );
    if( !timeoutPage.equals( newTimeoutPage ) ) {
      String pattern
        = "org.eclipse.swt.Request.getInstance().setTimeoutPage( \"{0}\" );";
      Object[] param = new Object[] { newTimeoutPage };
      String jsCode = MessageFormat.format( pattern, param );
      IServiceStateInfo stateInfo = ContextProvider.getStateInfo();
      HtmlResponseWriter out = stateInfo.getResponseWriter();
      out.write( jsCode );
Re: How to change timeout page [message #652235 is a reply to message #651340] Thu, 03 February 2011 04:54 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan Furnadjiev
currently there is no public APIs to customize the timeout page. We are
aware of this and we are looking for a solution - see bug:
284422: Improve session timeout notification
https://bugs.eclipse.org/bugs/show_bug.cgi?id=284422
But... you can use an internal API to render your customize timeout page
- see the snippet below:
String newTimeoutPage = "<html><body>My custom timeout page</body></html>";
String pattern
JSExecutor.executeJS( jsCode );
Please consider, that this snippet uses internal APIs, both on client
and server, that are subject to change without notice!
HTH,
Ivan
On 1/29/2011 4:43 PM, evol wrote:
> Hi, I just wonder how can I chage session timeout page. I guess it can
> throws IOException
> String pattern
> \"{0}\" );";
Re: How to change timeout page [message #1003366 is a reply to message #652235] Sun, 20 January 2013 22:37 Go to previous messageGo to next message
Ronald So is currently offline Ronald So
We may have a need to redirect to a separate HTML page when session times out. I found this thread and Bug 284422, but the fix is basically what I see in RAP 1.5. Does RAP support a customized HTML page for session timeout instead of the small pop up dialog box? We have a security concern because the error pop up simply puts on top of some potential sensitive data, and most of our customers are believed to want to remove these data from being shown on the screen when session times out.
Thanks!
Ronald
Re: How to change timeout page [message #1003502 is a reply to message #1003366] Mon, 21 January 2013 06:29 Go to previous message
Ralf Sternberg is currently offline Ralf Sternberg
Hi Ronald,
292607 is your bug. I guess this is something we should consider for RAP
2.1. Until the bug is fixed, you may can find a hack based on the fix
for bug 388249?
HTH, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Previous Topic:RAP 2.0 War deployment issue
Next Topic:View drag and drop
Current Time: Sat May 18 13:56:07 EDT 2013
Powered by FUDForum. Page generated in 0.03158 seconds
