| Proxy only for HTTP [message #1003454] |
Mon, 21 January 2013 04:27  |
Drusselnahg Borus Messages: 3 Registered: November 2012 |
Junior Member |
Hello everybody !
I'm inside a strange network at my workplace, where i get both internet (using a proxy), and a VPN.
For the VPN, i know only the IP range (172.16.0.0/12).. But i access the hosts using their hostname (which can vary, and no wildcard rule can apply ..)
But when i use some connections using the remote system explorer, i get:
Failed to connect , proxy error, ...)
What can i do to disable proxy for some ports/ip range ?
| Re: Proxy only for HTTP [message #1003459 is a reply to message #1003454] |
Mon, 21 January 2013 04:32  |
Junior Member |
For information, this is what i get:
proxy error: Proxy Error ( The specified Secure Sockets Layer (SSL) port is not allowed. Forefront TMG is not configured to allow SSL requests from this port. Most Web browsers use port 443 for SSL requests. )
In my proxy settings, i put "HTTP", "HTTPS", and left SOCKS setting cleared.
But the SOCKS is still checked, i cannot remove it from the "Manual" setting.
FUDForum. Page generated in 0.02297 seconds
