| problem running a xtext file [message #1002501] |
Fri, 18 January 2013 13:06  |
Amine BEN Messages: 2 Registered: January 2013 |
Junior Member |
I generated a xtext grammar from an existing genmodel. When I tried to run the generated file an error occured. here is the error
[main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - java.util.zip.ZipException: error in opening zip file
org.eclipse.emf.common.util.WrappedException: java.util.zip.ZipException: error in opening zip file
at org.eclipse.xtext.mwe.PathTraverser.traverseArchive(PathTraverser.java:63)
at org.eclipse.xtext.mwe.PathTraverser.findAllResourceUris(PathTraverser.java:44)
at org.eclipse.xtext.mwe.PathTraverser.resolvePathes(PathTraverser.java:33)
at org.eclipse.xtext.mwe.RuntimeResourceSetInitializer.getPathToUriMap(RuntimeResourceSetInitializer.java:54)
at org.eclipse.xtext.mwe.RuntimeResourceSetInitializer.getInitializedResourceSet(RuntimeResourceSetInitializer.java:72)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.findModule(Mwe2Runner.java:93)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:61)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
at org.eclipse.xtext.mwe.PathTraverser.traverseArchive(PathTraverser.java:52)
... 9 mo
Thank you in advance
FUDForum. Page generated in 0.07197 seconds
