Home » Eclipse Projects » Eclipse 4 » How to do ContextInjectionFactory.make with paramatrized constructor?
How to do ContextInjectionFactory.make with paramatrized constructor? [message #1002456] Fri, 18 January 2013 11:10 Go to next message
Alex Kipling is currently offline Alex Kipling
I have a widget named TableToolbar which has a parametrized constructor.
class TableToolbar{
@Inject
MyData data;
public TableToolbar(Composite parentComposite) {
func(data);
I would like to Inject the data from IEclipseContext into it, before starting the constructor.
This I usually do with
ContextInjectionFactory.make(TableToolbar, eclipseContext);
Now I have a specific Composite, which I need to pass a specific Composite to the TableToolbar constructor.
Is it possible?
P.S.
I can not inject the data later by
TableToolbar tableToolbar= new TableToolbar(composite);
ContextInjectionFactory.inject(tableToolbar, context);
because the injected data are needed inside the constructor.
Re: How to do ContextInjectionFactory.make with paramatrized constructor? [message #1002555 is a reply to message #1002456] Fri, 18 January 2013 15:38 Go to previous messageGo to next message
Frank Benoit is currently offline Frank Benoit
Member
How about create a child context and set your parentComposite there, then use it to make the object
c2 = context.createChild();
c2.set( Composite.class, myParentComposite );
ContextInjectionFactory.make(TableToolbar.class, c2);
Frank
Re: How to do ContextInjectionFactory.make with paramatrized constructor? [message #1002597 is a reply to message #1002555] Fri, 18 January 2013 17:52 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
That's correct still he'll fail because workflow is this:
a) run constructor code
b) do field injection
c) do method injection
d) run @PostConstruct
Hence he'll has to have MyData as an constructor argument.
Tom
Am 18.01.13 21:38, schrieb Frank Benoit:
> Frank
Re: How to do ContextInjectionFactory.make with paramatrized constructor? [message #1002937 is a reply to message #1002597] Sat, 19 January 2013 17:27 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot Cela
This doesn't make sense because you can not expect a (non-static)field of an object to be set before its constructor returns (i.e. the object is created). First you have to have an object (which you don't have until the constructor returns) and then set its fields. DI can't break these rules.
Re: How to do ContextInjectionFactory.make with paramatrized constructor? [message #1003444 is a reply to message #1002937] Mon, 21 January 2013 04:02 Go to previous messageGo to next message
For now I had to move all the constructor logic into a separate method init().
  1. Now I can manually create the Object, with a concrete composite as parameter.
  2. Then I Inject the missing fields, by using the ContextInjectionFactory
  3. Then I call the init(), which contains all the constructor logic using injected variables.
With other words I am changing the lifecycle, to do the injection, before calling the constructor.
class TableToolbar{
@Inject
MyData data;
public TableToolbar(Composite parentComposite) {}
public void init(){
 func(data);
        TableToolbar toolbar = new TableToolbar(containerTop);
        ContextInjectionFactory.inject(toolbar, context);
        toolbar.init();
Re: How to do ContextInjectionFactory.make with paramatrized constructor? [message #1003461 is a reply to message #1003444] Mon, 21 January 2013 04:35 Go to previous messageGo to next message
I didn't look at the code but you can not do any injection except constructor argument injection before the constructor returns.
Why don't you use @PostConstruct? Remove the @Inject from data and, run your constructor and add a method :
@PostConstruct
public void init(MyData data){
this.data=data;
func(data);
and you don't need CIF or manually call init.
Re: How to do ContextInjectionFactory.make with paramatrized constructor? [message #1003557 is a reply to message #1003461] Mon, 21 January 2013 09:10 Go to previous message
Thnx Sopot, now my code looks as following:
class TableToolbar{
@Inject
MyData data;
@PostConstruct
public void init(){
 func(data);
ContextInjectionFactory.inject(toolbar, context); //calls @PostConstruct annotated method
I still have to inject manually, because I would like to create the TableToolbar myselfe. It makes the code more understandable, than using Tom's version, with a child container:
Previous Topic:How to clear persisted state if application model has changed?
Next Topic:Do Addons have another Context, than the parts?
Current Time: Thu May 23 00:20:47 EDT 2013
Powered by FUDForum. Page generated in 0.01848 seconds
