| Limiting scoped elements, but allowing simple names to be used [message #1002595] |
Fri, 18 January 2013 17:53  |
Joost van Pinxten Messages: 42 Registered: November 2012 |
Member |
First off, Xtext has some very awesome defaults. I like them very much! Good work.
Now then, I want to achieve the same behaviour as the default scoping provider, but for a subset of all available elements. I use FQN to achieve hiding/accessing of duplicated names.
The grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model: applications+=Application*;
Application: "Application" name=ID "{" tasks+=Task* "}";
Task: "Task" name=ID "{" ports += Port* edges += Edge* "}";
Port: "Port" name=ID ";";
Edge: "Edge" "to" from=[Port | FQN] ";";
FQN: ID ("."ID )* ;
Allowing me to define models like:
Application app1 {
Task task1 {
Port p1;
Edge a to p1;
Task task2 {
Port p1;
Edge a to task1.p1;
Application app2 {
Task task1 {
Port p1;
Edge a to app1.task1.p1; // Should not be allowed, as app1 !== app2
I want the default scoping/proposal behavior, but then limited to Application, as the following code intends to do:
public IScope scope_Port(Edge context, EReference reference) {
Application app = (Application) context.eContainer().eContainer();
List<Port> elements = new ArrayList<Port>();
for (Task t : app.getTasks()) {
elements.addAll(t.getPorts());
return Scopes.scopeFor(elements);
But, then the simple name is forced (i.e. just p1 is allowed); injecting the DefaultDeclarativeQualifiedNameProvider and using this in combination with a NULLSCOPE or a scope containing the Tasks/Application as outer scope also does not give me the correct behavior, as then the full FQN always needs to be specified.
Might have a look into exporting the IEObjectDescriptions, but it seems this will only work when exporting from a file to another. Can you give me pointers on what the way to go is? If anything is unclear, let me know, I'll rephrase or add the details.
| Re: Limiting scoped elements, but allowing simple names to be used [message #1002922 is a reply to message #1002725] |
Sat, 19 January 2013 16:35  |
Member |
Thanks so much for the pointer, Alexander. So basically, I needed two elements: delegateGetScope, to get the original behavior; and then to use the FilteringScope to weed out the ones that are explicitly not accessible. Instead of checking by FQN, I am checking by containment, as I think that is more resilient to changes in the model/grammar.
EObject parent = context;
// Check for containment in an Application object
while (parent != null && !(parent instanceof Application)) {
parent = parent.eContainer();
if(parent == null) {
return IScope.NULLSCOPE;
final Application app = (Application) parent;
// Add all port objects that are in this Application
// get the default/original scope, which uses shorthand FQNs
IScope originalScope = delegateGetScope(context, reference);
Predicate<IEObjectDescription> predicate = new Predicate<IEObjectDescription>(){
public boolean apply(IEObjectDescription input) {
if (input == null) {
return false;
EObject parent = input.getEObjectOrProxy();
// Search for the containing Application again
// Only return true if the app is the same object as the application that contains this element
return app.equals(parent);
// Apply the predicate to the original scope
return new FilteringScope(originalScope, predicate);
There is some stuff out there, for example in the Xtext documentation, and on the itemis blog, but none of them give an actual overview of methods, classes, what they do and how they should be applied. As I have stated before, Xtext works brilliantly out of the box, but it is a pain to search through all of the classes to find what you need. The FilteringScope class is only documented with a few comments, but I did not find any pointers to it anywhere in the documentation. And I've been missing those pointers quite a lot... But perhaps I'm just spoiled with the quality of the documentation of the Qt library
FUDForum. Page generated in 0.09332 seconds
