Home » Eclipse Projects » BIRT » crosstab dimension drilldown
crosstab dimension drilldown [message #254122] Sat, 01 September 2007 00:10 Go to next message
Eclipse User
Originally posted by: spaddock.rogers.com
Instead of showing all possible dimension levels, is it possible to
drill-down into them.
For example, in the common product line crosstab example what if you
wanted to drill-down into the motorcycle product line and see how the
different motorcycles were doing.
With the Mondrian product you see the cubes with the typical (+) interface
to expand the dimensions, is this possible in BIRT? if not is it planned?
Shayne
Re: crosstab dimension drilldown [message #254143 is a reply to message #254122] Sun, 02 September 2007 21:47 Go to previous messageGo to next message
Tianli Zhang is currently offline Tianli Zhang
Hi Shayne
The drill-down feature hasn't supported yet. I've no idea whether it is
planed. But it is really a good point. If any process and plan will tell
you. Thanks!
Regards!
Re: crosstab dimension drilldown [message #254153 is a reply to message #254143] Sun, 02 September 2007 22:20 Go to previous messageGo to next message
The drill-down and drill-up feature will be supported on BIRT2.3.1:)
Regards!
Re: crosstab dimension drilldown [message #254434 is a reply to message #254153] Tue, 04 September 2007 11:34 Go to previous messageGo to next message
Eclipse User
For now I could create two different report designs and just have a
hyperlink.
Is there a way to use the cube in multiple reports? Most of the work is
done building the cube so it would be a shame to have to recreate the same
cube for multiple reports.
Great news about it being available in 2.3.1
Kindest regards,
Shayne
Re: crosstab dimension drilldown [message #254496 is a reply to message #254434] Tue, 04 September 2007 21:08 Go to previous messageGo to next message
Of course you can, define your cube in a rptlibrary and publish the
library. Then others reports can use this cube from library.
Best regards!
Tianli
Re: crosstab dimension drilldown [message #254500 is a reply to message #254496] Tue, 04 September 2007 22:09 Go to previous messageGo to next message
Eclipse User
What I meant was to be able to reuse the same cube that just got populated
full of data from the previous report.
Are you saying it's possible to reuse the cube in other reports once it's
calculated all it's dimensions and measures? Obviously within a
reasonable amount of time without being refreshed.
At design time the cube is simple to build. At runtime complex cubes take
a while to generate.
-Shayne
> Best regards!
> Tianli
Re: crosstab dimension drilldown [message #1002274 is a reply to message #254500] Fri, 18 January 2013 04:48 Go to previous messageGo to next message
g g is currently offline g g
I also have requirement to re-use the cube (populated with data) in multiple reports. Is there any update on questions posted by Tianli?
Re: crosstab dimension drilldown [message #1002562 is a reply to message #1002274] Fri, 18 January 2013 15:58 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Currently re-using populated cubes is not supported.
Jason
Jason Weathersby
BIRT Exchange
Re: crosstab dimension drilldown [message #1002844 is a reply to message #1002274] Sat, 19 January 2013 11:05 Go to previous message
Jason, thanks for reply.
Previous Topic:How to add User Defined Property and Named Expression programmatically?
Next Topic:Problem in passing query string parameters from HTML to beforeOpen method of BIRT
Current Time: Sun May 19 18:54:22 EDT 2013
Powered by FUDForum. Page generated in 0.01874 seconds
