Home » Eclipse Projects » BIRT » BIRT 3.7.1 and Java 7 support(Is Java 7 supported with Birt version 3.7.1 since Java 6 is EOL)
BIRT 3.7.1 and Java 7 support [message #997761] Tue, 08 January 2013 12:29 Go to next message
Kathy Hansen is currently offline Kathy Hansen
Re: BIRT 3.7.1 and Java 7 support [message #997878 is a reply to message #997761] Tue, 08 January 2013 18:07 Go to previous messageGo to next message
Michael Williams is currently offline Michael Williams
I haven't had any problems with it, but I don't think it's on the "official" list.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: BIRT 3.7.1 and Java 7 support [message #997886 is a reply to message #997878] Tue, 08 January 2013 18:23 Go to previous messageGo to next message
BIRT 4.2 supports Java 7.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: BIRT 3.7.1 and Java 7 support [message #1002459 is a reply to message #997878] Fri, 18 January 2013 11:15 Go to previous messageGo to next message
Since Java 6 is EOL when will it be on the official list? Who can I contact since 2.6.2 and 4.2.1 are supported.
Re: BIRT 3.7.1 and Java 7 support [message #1002475 is a reply to message #1002459] Fri, 18 January 2013 11:54 Go to previous messageGo to next message
Where do you see that 2.6.2 has been validated on Java 7? In the release documentation, I only see 5 and 6. Same for 3.7. Java 7 doesn't show up in the project plan til 4.2. Let me know.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: BIRT 3.7.1 and Java 7 support [message #1002484 is a reply to message #1002459] Fri, 18 January 2013 12:17 Go to previous messageGo to next message
I have a note from Steve Franciso:
For Java 7 support, we do have some products running the Helios version (IES 3.6.x) on a Java 7 runtime. This is supported as 'secondary support' meaning we will accept bug reports if you have problems running with Java 7 specifically, but may need your assistance in debugging/reproducing issues. We have not had any Java 7 specific issues so far that I'm aware of.
Re: BIRT 3.7.1 and Java 7 support [message #1002488 is a reply to message #1002484] Fri, 18 January 2013 12:29 Go to previous messageGo to next message
Like I said before, I have Java 7 and have MANY older version running on my machine, with no issues. If you encounter an issue, you could always log a bug in the bugzilla. You could also log a bugzilla for just this issue and see what they say about validating the older versions or supporting any Java 7 issues that may arise.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: BIRT 3.7.1 and Java 7 support [message #1002497 is a reply to message #1002484] Fri, 18 January 2013 12:58 Go to previous messageGo to next message
Thanks Michael. I am looking for official support since my product ships BIRT I agree we found no problems in our testing either. Thanks
Re: BIRT 3.7.1 and Java 7 support [message #1002568 is a reply to message #1002497] Fri, 18 January 2013 16:14 Go to previous messageGo to next message
If you file a bugzilla entry, please place the info in here, for future reference. Thanks!
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: BIRT 3.7.1 and Java 7 support [message #1005755 is a reply to message #1002568] Mon, 28 January 2013 10:04 Go to previous messageGo to next message
Do you happen to know who the official owner of Birt is? I would like to get an official response on Birt and Java 7 since we have clients asking about support for java 7 and the web site http://www.eclipse.org/projects/project-plan.php?planurl=http://www.eclipse.org/birt/project/plan/birt_project_plan_3_7_1.xml#target_environments does not show support and it makes us look bad. Thanks so much.
Re: BIRT 3.7.1 and Java 7 support [message #1005786 is a reply to message #1005755] Mon, 28 January 2013 12:49 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Kathy
This issue was brought up on the BIRT PMC meeting today. BIRT is owned by the community and Eclipse. The BIRT PMC manages the project and since the Eclipse platform added Java 7 support in version 3.7.1, the BIRT team will also support Java 7 in 3.7.1 and will work on any bug associated with those versions.
Jason Weathersby
BIRT PMC
Jason Weathersby
BIRT Exchange
Re: BIRT 3.7.1 and Java 7 support [message #1005787 is a reply to message #1005786] Mon, 28 January 2013 12:49 Go to previous message
BTW- Here was the announcement on the Platform:
http://www.infoq.com/news/2011/09/eclipse-indigo-371
Jason Weathersby
BIRT Exchange
Previous Topic:What properties are passed to an IScriptFunctionExecutor in IScriptFunctionContext?
Next Topic:decode string of a parameter value
Current Time: Sat May 18 10:05:00 EDT 2013
Powered by FUDForum. Page generated in 0.02325 seconds
