Home » Eclipse Projects » Target Management » Juno - FTP
Juno - FTP [message #1002548] Fri, 18 January 2013 15:20 Go to next message
Mcp Lecomte is currently offline Mcp Lecomte
New to Eclipse, I downloaded Juno Classic (installed WPT, PDT). Followed (probably but sure old book) they used KLOMP for exporting through ftp. So far I don't have any ftp capability.
Can I use WebDav, ftp, Klomp, or something else with Juno ? How to ?
Concerned project: Web (html, php, ..).
Thank.
Re: Juno - FTP [message #1003780 is a reply to message #1002548] Mon, 21 January 2013 20:01 Go to previous messageGo to next message
David McKnight is currently offline David McKnight
I'm assuming you're trying to connect to an FTP server via an RSE
connection. What kind of connection have you defined (FTP Only)?
"Mcp Lecomte" <forums-noreply@xxxxxxxx> wrote in message
news:kdjffl$f0m$1@xxxxxxxxe.org...
> Hello,
> Thank.
Re: Juno - FTP [message #1003919 is a reply to message #1002548] Tue, 22 January 2013 03:27 Go to previous message
Martin Oberhuber is currently offline Martin Oberhuber
I suggest you Help > Install New Software ... and then from
http://download.eclipse.org/releases/juno
you install
- Remote System Explorer
- PHP Development Tools (PDT)
- Web Development Tools
- XML Editor
and whatever else you want. RSE will give you the FTP connectivity.
If you start with the Java EE package from http://www.eclipse.org/downloads/ instead of Classic then you'll have most stuff already preinstalled (I think only PDT would not be preinstalled).
Previous Topic:Setting remote launch as default debug
Next Topic:Can't run tests from Eclipse, ClassCastException
Current Time: Fri May 24 14:51:09 EDT 2013
Powered by FUDForum. Page generated in 0.01703 seconds
