Home » Language IDEs » PDT » content assist triggers on ";"
content assist triggers on ";" [message #1002534] Fri, 18 January 2013 14:28 Go to next message
John Schleigh is currently offline John Schleigh
When I type the ";" at the end of each line, content assist pops up and will add the first item on the list (usually $_COOKIE). I know I can adjust the delay or even disable the content assist, but I like it in most occasions. It just seems to be firing at times that do not make sense. Is there a way to control what patterns trigger the popup? I don't think it is reasonable to expect people to key in "alt+/" between ";" and "enter".
Re: content assist triggers on ";" [SOLVED] [message #1002539 is a reply to message #1002534] Fri, 18 January 2013 14:40 Go to previous message
It seems a yii-eclipse plugin update was the culprit. I uninstalled the yii-eclipse and the content assist started behaving again.
Previous Topic:Helios does'nt stops on breakpoints
Next Topic:How to get most recent php version - Eclipse Indigo/PDT windows vista
Current Time: Sun May 19 06:54:08 EDT 2013
Powered by FUDForum. Page generated in 0.01563 seconds
