| Muster roll report using Birt [message #1000778] |
Tue, 15 January 2013 07:23  |
Bhaskar N Messages: 3 Registered: January 2013 |
Junior Member |
I am new to this forum and i am looking for a solution to prepare the report.
earlier i was using Crystal reports to Prepare Reports. as the requirement of our customer changed, we changed our reporting tool to Birt and we are preparing old crystal reports using Birt Reporting tool.
So, please can any one Help me out to generate the Report as shown in the image which i have attached....?
| Re: Muster roll report using Birt [message #1000998 is a reply to message #1000778] |
Tue, 15 January 2013 15:51   |
It might depend on how your data is set up, but this appears to be what you'd use a crosstab for. The date field would be the column dimension, the user info would be the row dimensions and the times and remark fields would be the measures. To use strings as measures, you'd need to remember to set the type to string and the aggregation to first, in the dataCube. If you show a small sample of how the data looks in your result set and let me know your BIRT version, I could probably make you a quick sample.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
FUDForum. Page generated in 0.01915 seconds
