| Eclipse 3.6 rcp to eclipse 4 rcp [message #1001798] |
Thu, 17 January 2013 06:48  |
Thomas Bittner Messages: 1 Registered: December 2012 |
Junior Member |
i have an rcp application written in eclipse 3.6. Now I try to get it running under Eclipse 4.2.
Inside Eclipse it is running just fine, but when i export it, i always get a nullpointer exception.
The exception is thrown by org.eclipse.e4.ui.internal.workbenche.ModelServiceImpl. Is it possible that this Problem is caused by the e4 application model which i didn't use?
Any Help how i could solve this Problem is appreciated.
Thomas
!SESSION 2013-01-16 20:19:53.539 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_06
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_AT
Command-line arguments: -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.osgi 4 0 2013-01-16 20:19:55.154
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.<init>(ModelServiceImpl.java:92)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:442)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:182)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:557)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at at.stift.inventar.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
| Re: Eclipse 3.6 rcp to eclipse 4 rcp [message #1002330 is a reply to message #1001798] |
Fri, 18 January 2013 07:13  |
sumit singh Messages: 73 Registered: October 2012 Location: Bangalore |
Member |
Its creating ModelServiceImpl object with IEclipseContext and then it try to find IEventBroker in this context with is not present so then in next step its throwing java.lang.NullPointerException
public ModelServiceImpl(IEclipseContext appContext) {
if (appContext == null)
return;
IEventBroker eventBroker = appContext.get(IEventBroker.class);
eventBroker.subscribe(UIEvents.UIElement.TOPIC_WIDGET, hostedElementHandler);
Are you exporting with all dependency..?
[Updated on: Fri, 18 January 2013 07:14] Report message to a moderator
FUDForum. Page generated in 0.01798 seconds
