Home » Eclipse Projects » EclipseLink » @Index does not work(EclipseLink is not creating any index)
@Index does not work [message #1002227] Fri, 18 January 2013 03:10 Go to next message
Guido Häp is currently offline Guido Häp
Hallo.
I am using EclipseLink 2.4.1 and a Oracle Database.
My entity looks like this:
@Entity
@Index(name="INDEX1", columnNames={"MATERIALLOT","MATERIALSUBLOT"})
@Table(name = "MM_MatSublot")
public class MaterialSublotEntity {
@Index
@Column(name="MATERIALLOT")
private MaterialLotEntity materialLot;
@Index
@Column(name="MATERIALSUBLOT")
private MaterialSublotEntity parentSublot;
EclipseLink does not create the indexes.
What can be the reason?
Re: @Index does not work [message #1002416 is a reply to message #1002227] Fri, 18 January 2013 09:37 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris Delahunt
Have you specified the "eclipselink.ddl-generation" and is EclipseLink generating the fields and tables correctly? Try turning EclipseLink logging to Fine or Finest and see the statements being used for your MM_MatSublot table.
Best Regards,
Chris
Re: @Index does not work [message #1006477 is a reply to message #1002416] Thu, 31 January 2013 07:51 Go to previous message
Now it works.
I don't know what is different.
Before the Tables where created correctly. Just the indexes where missing.
After I could create most of the indexes today I still have a problem with indexes in CollectionTables.
See: http://www.eclipse.org/forums/index.php/m/1006474/#msg_1006474
Previous Topic:EL OSGi EntityManagerFactoryBuilder creates EntityManagerFactory for different DBs wrongly
Next Topic:DescriptorEventAdapter
Current Time: Sat May 18 22:17:34 EDT 2013
Powered by FUDForum. Page generated in 0.01625 seconds
