| testexec from Windows connect to linux AUT failed at the end [message #1001197] |
Wed, 16 January 2013 03:33  |
posia han Messages: 42 Registered: December 2012 |
Member |
The version of jubula is standalone 1.3.0 .I start autagent on Linux ,and connect the AUT of Linux successfully at the Jubula LTE from windows machine, but when i used testexec command, the AUT started uncompletely, can you help me?
Errror message in the Client.log:
2013-01-17 18:25:59.078 [main] ERROR o.e.jubula.tools.i18n.CompSystemI18n - Cannot find I18N-key in resource bundles: newTab
java.util.MissingResourceException: No entry found for key: newTab
at org.eclipse.jubula.tools.i18n.CompSystemI18n.getStringInternal(CompSystemI18n.java:128) ~[org.eclipse.jubula.tools_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.tools.i18n.CompSystemI18n.getString(CompSystemI18n.java:80) ~[org.eclipse.jubula.tools_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.client.core.utils.StringHelper.initMap(StringHelper.java:154) [org.eclipse.jubula.client.core_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.client.core.utils.StringHelper.<init>(StringHelper.java:56) [org.eclipse.jubula.client.core_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.client.core.utils.StringHelper.getInstance(StringHelper.java:85) [org.eclipse.jubula.client.core_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.client.core.businessprocess.ComponentNamesBP.initDefaultNames(ComponentNamesBP.java:743) [org.eclipse.jubula.client.core_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.client.core.businessprocess.ComponentNamesBP.<init>(ComponentNamesBP.java:158) [org.eclipse.jubula.client.core_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.client.core.businessprocess.ComponentNamesBP.getInstance(ComponentNamesBP.java:167) [org.eclipse.jubula.client.core_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.client.core.persistence.ProjectPM.loadProjectInROSession(ProjectPM.java:507) [org.eclipse.jubula.client.core_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.app.cmd.batch.ExecutionController.loadProject(ExecutionController.java:776) [org.eclipse.jubula.app.cmd_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.app.cmd.batch.ExecutionController.prepareExecution(ExecutionController.java:573) [org.eclipse.jubula.app.cmd_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.app.cmd.batch.ExecutionController.executeJob(ExecutionController.java:410) [org.eclipse.jubula.app.cmd_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.app.cmd.Client.doRun(Client.java:81) [org.eclipse.jubula.app.cmd_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.client.cmd.AbstractCmdlineClient.run(AbstractCmdlineClient.java:407) [org.eclipse.jubula.client.cmd_1.3.0.201210161256.jar:na]
at org.eclipse.jubula.client.cmd.AbstractLauncher.start(AbstractLauncher.java:26) [org.eclipse.jubula.client.cmd_1.3.0.201210161256.jar:na]
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) [org.eclipse.equinox.app_1.3.100.v20110321.jar:na]
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) [org.eclipse.osgi_3.7.2.v20120110-1415.jar:na]
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) [org.eclipse.osgi_3.7.2.v20120110-1415.jar:na]
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344) [org.eclipse.osgi_3.7.2.v20120110-1415.jar:na]
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) [org.eclipse.osgi_3.7.2.v20120110-1415.jar:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.6.0_33]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) ~[na:1.6.0_33]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) ~[na:1.6.0_33]
at java.lang.reflect.Method.invoke(Method.java:597) ~[na:1.6.0_33]
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622) [org.eclipse.equinox.launcher_1.2.0.v20110502.jar:na]
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577) [org.eclipse.equinox.launcher_1.2.0.v20110502.jar:na]
at org.eclipse.equinox.launcher.Main.run(Main.java:1410) [org.eclipse.equinox.launcher_1.2.0.v20110502.jar:na]
at org.eclipse.equinox.launcher.Main.main(Main.java:1386) [org.eclipse.equinox.launcher_1.2.0.v20110502.jar:na]
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source) [i4jruntime.jar:na]
at com.exe4j.runtime.WinLauncher.main(Unknown Source) [i4jruntime.jar:na]
at com.install4j.runtime.launcher.WinLauncher.main(Unknown Source) [i4jruntime.jar:na]
2013-01-17 18:26:25.468 [Worker-0] ERROR o.e.j.c.c.c.AUTConnection - Connection to AUT could not be established.
2013-01-17 18:26:25.468 [Worker-0] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error ocurred: Could not connect to AUT
[Updated on: Thu, 17 January 2013 19:58] Report message to a moderator
| Re: testexec from Windows connect to linux AUT failed at the end [message #1002208 is a reply to message #1002197] |
Fri, 18 January 2013 02:12   |
Member |
Hi ALEX,
Follow what you suggest,I tried testexec command on AUT local machine,but The same problem comes again. At this time,I also added -data parameter into .xml file.
1.The content of .xml file:
<configuration>
<project>NetNumen</project>
<version>1.0</version>
<autconfig>P2B4SP002Setup@CGSL</autconfig>
<dbscheme>Netnumen</dbscheme>
<dbuser>system</dbuser>
<dbpw>abc123</dbpw>
<server>192.168.0.83</server>
<port>60000</port>
<language>zh_CN</language>
<testsuite>SP002SetupSuit</testsuite>
<data>/tools/jubula/jubula/workspace</data>
<datadir>/datafile/testdata</datadir>
<resultdir>/datafile/testdata</resultdir>
</configuration>
2.The error log:
2013-01-18 16:14:09.150 [main] ERROR o.e.jubula.tools.i18n.CompSystemI18n - Cannot find I18N-key in resource bundles: previous
java.util.MissingResourceException: No entry found for key: previous
at com.install4j.runtime.launcher.Launcher.main(Unknown Source) [i4jruntime.jar:na]
2013-01-18 16:14:35.590 [Worker-0] ERROR o.e.j.c.c.c.AUTConnection - Connection to AUT could not be established.
2013-01-18 16:14:35.605 [Worker-0] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error ocurred: Could not connect to AUT:test
Attachment: swing.bmp
(Size: 942.77KB, Downloaded 19 times)
[Updated on: Fri, 18 January 2013 03:20] Report message to a moderator
FUDForum. Page generated in 0.01712 seconds
