| Adding Root Domain Object on Diagram Creation [message #1001959] |
Thu, 17 January 2013 11:02  |
Dan Simkins Messages: 36 Registered: December 2012 |
Member |
I have created a custom Diagram Editor by extending DiagramEditor.
I have created a custom New Diagram Wizard by extending BasicNewResourceWizard.
I am struggling to determine the correct place to automatically add the root domain object on diagram creation. I have tried after opening the newly created diagram as follows:
try
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().openEditor( editorInput, editorID );
ModelPackageImpl.init();
Model model = ControlFactory.eINSTANCE.createModel();
diagram.eResource().getContents().add( model );
and whilst I get no exception, the resultant new diagram file does not contain the root domain object.
Any pointers would be greatly appreciated.
Dan
| Re: Adding Root Domain Object on Diagram Creation [message #1001985 is a reply to message #1001973] |
Thu, 17 January 2013 11:52   |
Member |
Hi Michael,
That's what I'm trying to do, but failing miserably - I seem to have 'code' blindness!!
I am trying to add it (as per above) in the performFinish method. I have tried in a number of places. For instance, after creating the diagram (using - Diagram diagram = Graphiti.getPeCreateService().createDiagram( diagramTypeId, diagramName, true ) ), if I attempt to create and add the root domain at that point, I get a null pointer exception on execution at:
I'm sure I must be doing something really dumb!
Dan
[Updated on: Thu, 17 January 2013 13:03] Report message to a moderator
| Re: Adding Root Domain Object on Diagram Creation [message #1002080 is a reply to message #1001985] |
Thu, 17 January 2013 17:23   |
Hallvard Traetteberg Messages: 539 Registered: July 2009 Location: Trondheim, Norway |
On 17.01.13 08.52, Dan Simkins wrote:
> Hi Michael,
> 'code' blindness!!
> root domain at that point, I get a null pointer exception on execution of:
It seems diagram is not inside a resource, hence eResource() returns
null. Have you created a ResourceSet and a Resource and added the
diagram? Below I've pasted code from
org.eclipse.graphiti.examples.common.FileService that does that. Insert
a call to it before the line that gives an NPE.
Hallvard
package org.eclipse.graphiti.examples.common;
public class FileService {
* @since 0.9
public static void createEmfFileForDiagram(URI diagramResourceUri,
final Diagram diagram) {
// Create a resource set and EditingDomain
final TransactionalEditingDomain editingDomain =
GraphitiUiInternal.getEmfService()
.createResourceSetAndEditingDomain();
final ResourceSet resourceSet = editingDomain.getResourceSet();
// Create a resource for this file.
final Resource resource = resourceSet.createResource(diagramResourceUri);
final CommandStack commandStack = editingDomain.getCommandStack();
commandStack.execute(new RecordingCommand(editingDomain) {
protected void doExecute() {
resource.setTrackingModification(true);
resource.getContents().add(diagram);
save(editingDomain, Collections.<Resource, Map<?, ?>> emptyMap());
editingDomain.dispose();
Hallvard
| Re: Adding Root Domain Object on Diagram Creation [message #1002090 is a reply to message #1002080] |
Thu, 17 January 2013 17:59   |
Member |
Hi Hallvard,
Thanks for your response.
In my initial post, I had tried to add the root domain object after the call to createEmfFileForDiagram. My apologies - my subsequent post was misleading in that I tried adding the root domain object before the call to createEmfFileForDiagram and as you correctly noted, no resource had been created and thus I got a NPE.
My problem still remains the same - the essential sequence is as below, however, the resultant diagram file (which is fine in all other respects) does not contain my root domain object:
Diagram diagram = Graphiti.getPeCreateService().createDiagram( diagramTypeId, diagramName, true );
IFile diagramFile = diagramFolder.getFile( diagramName + "." + editorExtension );
URI uri = URI.createPlatformResourceURI( diagramFile.getFullPath().toString(), true );
FileService.createEmfFileForDiagram( uri, diagram );
String providerId = GraphitiUi.getExtensionManager().getDiagramTypeProviderId( diagram.getDiagramTypeId() );
DiagramEditorInput editorInput = new DiagramEditorInput( EcoreUtil.getURI( diagram ), providerId );
try
Apologies for the misleading NPE post.
I would really appreciate any ideas.
Dan
| Re: Adding Root Domain Object on Diagram Creation [message #1002522 is a reply to message #1002090] |
Fri, 18 January 2013 14:01   |
Dan,
You must link the diagram to it, too.
Hallvard
On 17.01.13 14.59, Dan Simkins wrote:
> Hi Hallvard,
> editorExtension );
> String providerId =
> try
> Thanks
> Dan
FUDForum. Page generated in 0.03040 seconds
