Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Texo] Problems handling JSON response
| [Texo] Problems handling JSON response [message #1001872] |
Thu, 17 January 2013 08:43  |
Bastian Wagenfeld Messages: 88 Registered: January 2013 |
Member |
Hi!
I am interessted in using Texo in a project. So I installed it and created a little servlet. The servlet itself works, but I have problems to handle the JSON string that is returned by the server.
The string looks like that (shortened version):
{"endRow":"25","_eclass":"response|ResponseType","totalRows":"26","status":"success","startRow":"0","data":[{"_eclass":"users|User","db_version":1,"db_Id":1,"_id":"1","name":"Testuser neu","role":{"_eclass":"users|Role","db_Id":2,"_id":"2","_proxy":true,"_uri":"ht.tp://localhost:8080/texo/jsonws/users|Role/2#","_title":"Admin"}, and so on....
So i create a JSONObject with that string. No I am not sure about the following steps.
I tried the following two conversions:
1.
JSONObject obj = new JSONObject(json);
JSONModelConverter mConv = ComponentProvider.getInstance().newInstance(
JSONModelConverter.class);
ResponseType type = (ResponseType) mConv.convert(obj);
This led to the following error message:
Exception in thread "main" java.lang.IllegalArgumentException: Fragment format not supported for fragment:
at org.eclipse.emf.texo.utils.ModelUtils.getTypeAndIdFromUri(ModelUtils.java:574)
at org.eclipse.emf.texo.resolver.DefaultObjectResolver.fromUri(DefaultObjectResolver.java:235)
at org.eclipse.emf.texo.json.JSONModelConverter.fromUri(JSONModelConverter.java:60)
at org.eclipse.emf.texo.json.BaseJSONModelConverter.resolveObject(BaseJSONModelConverter.java:120)
at org.eclipse.emf.texo.json.BaseJSONModelConverter.doConvert(BaseJSONModelConverter.java:107)
at org.eclipse.emf.texo.json.BaseJSONModelConverter.convertManyEReference(BaseJSONModelConverter.java:371)
at org.eclipse.emf.texo.json.BaseJSONModelConverter.convertContent(BaseJSONModelConverter.java:215)
at org.eclipse.emf.texo.json.BaseJSONModelConverter.doConvert(BaseJSONModelConverter.java:108)
at org.eclipse.emf.texo.json.BaseJSONModelConverter.convert(BaseJSONModelConverter.java:103)
at de.test.texo.test.TexoTest.getUser(TexoTest.java:132)
at de.test.texo.test.TexoTest.main(TexoTest.java:104)
2.
Second approach using the JSONEMFConverter:
JSONEMFConverter conv = ComponentProvider.getInstance().newInstance(
JSONEMFConverter.class);
DynamicEObjectImpl eObj = (DynamicEObjectImpl) conv.convert(obj);
Well, that is ok, but do I have any possibility to use the objects as objects of their own type? Maybe convert them from DynamicEObjectImpl?
I would be really happy about some help or hints that could help me with that.
Thanks a lot!
Bastian
| Re: [Texo] Problems handling JSON response [message #1001898 is a reply to message #1001872] |
Thu, 17 January 2013 09:22  |
Martin Taal Messages: 5049 Registered: July 2009 |
Seems to be a duplicate of: [Texo] Problems handling ResponseType
answered it there.
gr. Martin
On 01/17/2013 02:45 PM, Bastian Wagenfeld wrote:
> Hi!
> but I have problems to handle the JSON string that is returned by the server. The string looks like that (shortened
> version):
> and so on....
> 1.
> Exception in thread "main" java.lang.IllegalArgumentException: Fragment format not supported for fragment: at
> 2.
> DynamicEObjectImpl?
> Thanks a lot!
> Bastian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Current Time: Sat May 18 13:38:09 EDT 2013
Powered by FUDForum. Page generated in 0.01526 seconds
