Home » Modeling » ATL » ATL write to file
ATL write to file [message #1001783] Thu, 17 January 2013 06:15 Go to next message
Basma Moukhtar is currently offline Basma Moukhtar
Dears,
I try to write some strings in a sequence to a file.
I use the "writeTo" method as follows:
mySequence->collect(x | x.toString().writeTo('path'));
But this writes the last string only, so it overwrites what's in the file, I need to append.
So, what method shall I use?
Re: ATL write to file [message #1001887 is a reply to message #1001783] Thu, 17 January 2013 09:10 Go to previous message
Hugo Bruneliere is currently offline Hugo Bruneliere
You first have to build the full string you want to obtain, and then finally make a call to the writeTo method.
This latter does not provide concatenation support and simply overrides the current content of the file if existing.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Previous Topic:calling java in a query
Next Topic:The class 'VisitableCS' is not a valid classifier
Current Time: Tue Jun 18 01:25:48 EDT 2013
Powered by FUDForum. Page generated in 0.17608 seconds
