| AutoUpdate Text associated to a ConnectionDecorator [message #985951] |
Fri, 16 November 2012 15:40  |
Juan Quirós Messages: 4 Registered: November 2012 |
Junior Member |
Hello, first of all, congratulations for all the work which you have done!
I am using Graphiti and I am not able to resolve a problem.
Need: I have two elements connected by a connection. I need to show a text associated to the business object linked to the connection, and being able to edit the text.
My approach: I am using patterns. So I have created a class which extends AbstractConnectionPattern as the tutorial says. But I need edit the text, and this class does not support methods for Direct Editing Feature, so I have to create new classes which implement AbstractUpdateFeature and AbstractDirectEditingFeature, and combine patterns with "classical features".
The problem: Everything works fine except AutoUpdate. When I modify the value associated to the text in the domain-model, graphiti does not update it automatically en the diagram, I have to update manually.
Any idea?
Thanks in advance!
FUDForum. Page generated in 0.01902 seconds
