| Complex table structure using Nebula [message #993962] |
Tue, 25 December 2012 21:18  |
Prashant p Messages: 57 Registered: October 2012 |
Member |
I have a table with multiple rows which will be dynamic. In between these rows i will have summary row to count Sub Total Amount and Final row will be Summary row to populate Total Amount. Each row will contain Amount of particular Item.
For example
Category1 -Item1 -100 USD,
-Item2 -200 USD.
Subtoatal to Category 1 - 300 USD.
Category2 -Item1 -300 USD,
-Item2 -100 USD.
Subtoatal to Category 1 - 400 USD.
Now total Amount row will add subtotal amount of each category i.e 700 USD.
Is there any option to achieve this using Nebulla. Basically i am trying to replicate Webpage Table to SWT/Jface . Attached is the screenshot. Also please note that values in table will be populated from Database
Attachment: Table1.png
(Size: 34.31KB, Downloaded 59 times)
[Updated on: Tue, 25 December 2012 22:31] Report message to a moderator
| Re: Complex table structure using Nebula [message #995721 is a reply to message #994961] |
Sun, 30 December 2012 19:28   |
Member |
Thanks Edwin and Thomas. Do you mean Jface Grid Thomas? Also is it possible to populate DB values in Nat Table? 'coz my main intention is to populate table with DB values. And I should be able to add new row on ADD button click and insert values to DB. And also should be able to edit. Why i am asking this is Nat table is like Virtual table.
[Updated on: Sun, 30 December 2012 19:41] Report message to a moderator
| Re: Complex table structure using Nebula [message #1002112 is a reply to message #1001675] |
Thu, 17 January 2013 19:32   |
Member |
Thanks Dirk... . Is there any proper code sample available? 'coz i searched i din fine any accept for Nebula. Also i have one more Question.. will Nattable support Jface data binding. 'coz my application is completly SWT/JFace based, just for this table purpose i am using Nattable. Values in Table will be mapped to Form Field on click of any row item in table, this require databinding between Table and Form field.And table should be editable as well.
[Updated on: Thu, 17 January 2013 19:44] Report message to a moderator
| Re: Complex table structure using Nebula [message #1003049 is a reply to message #1002219] |
Sun, 20 January 2013 01:14  |
Member |
Thanks Dirk for your support and patience. :) My deadline is very short don't know if this R&D will work for me :) but will try out my best. As you know itz very hard to migrate web based solution to desktop based application on certain aspects.
| Re: Complex table structure using Nebula [message #1003052 is a reply to message #1002219] |
Member |
| Re: Complex table structure using Nebula [message #1003055 is a reply to message #1002219] |
Member |
| Re: Complex table structure using Nebula [message #1003058 is a reply to message #1002219] |
Member |
| Re: Complex table structure using Nebula [message #1003061 is a reply to message #1002219] |
Member |
| Re: Complex table structure using Nebula [message #1003064 is a reply to message #1002219] |
Member |
| Re: Complex table structure using Nebula [message #1003067 is a reply to message #1002219] |
Member |
| Re: Complex table structure using Nebula [message #1003072 is a reply to message #1002219] |
Member |
| Re: Complex table structure using Nebula [message #1003075 is a reply to message #1002219] |
Member |
| Re: Complex table structure using Nebula [message #1003078 is a reply to message #1002219] |
Member |
| Re: Complex table structure using Nebula [message #1003081 is a reply to message #1002219] |
Member |
FUDForum. Page generated in 0.03008 seconds
