Home » Newcomers » Newcomers » Creating a custom class with a pre decided template(Eclipse Plugin Developement)
Creating a custom class with a pre decided template [message #1001470] Wed, 16 January 2013 14:26 Go to next message
Rajeev Mishra is currently offline Rajeev Mishra
Hi All,
I want to develop a new java file creation wizard which will create a new java file in the workspace using a predeclared template.
Please guide me.
Any code snippet or similar thread link will be most useful for me.
Thanks and regards
Re: Creating a custom class with a pre decided template [message #1001622 is a reply to message #1001470] Wed, 16 January 2013 23:22 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane Begaudeau
Creating a brand new plug-in for that may be overkill. The Eclipse Java Development Tools already let you change the code generated while creating a new class. I've explained more about this on my blog (section 3.10) as part of a collection of articles on the JDT. You just need to configure the code templates for a new file in the properties of your project. You can then define, for example, a copyright header that should be generated on top of all your Java files. This template will be used for ll newly created classes in the project.
https://lh3.googleusercontent.com/-wdMRBn4HFcY/UM3eXAqvccI/AAAAAAAAKXc/GlWB4Cq5lIw/s826/Eclipse+JDT+-+Templates+01+Thumbnail.png
Now if you really want to create a wizard, you should have a look at Lars' tutorial.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
[Updated on: Wed, 16 January 2013 23:24]
Report message to a moderator
Re: Creating a custom class with a pre decided template [message #1017310 is a reply to message #1001622] Mon, 11 March 2013 10:59 Go to previous messageGo to next message
Tomas Bilka is currently offline Tomas Bilka
It would be nice to have a possibility to configure different Java class templates for certain "types" of classes.
F.e. when I create a new class that extends another specific class, i want to populate this new class with specific code template.
I would then hit "Create new class", then pop-up opens, I enter whch class i want to extend, new class is created with populated code template.
Or even better a possibility to define a new "Create My Specific Class" key shortcut. After hitting the key, the class would be created automatically.
Re: Creating a custom class with a pre decided template [message #1017464 is a reply to message #1017310] Mon, 11 March 2013 17:54 Go to previous message
David Wegener is currently offline David Wegener
Have you looked at the Java->Editor->Templates feature? This allows you to define code snippets that will can be inserted using content assist (Ctrl-Space). Type the name of the template in your source file and hit Ctrl-Space. You will be given the template as an option. You can define variables that correspond to class name, method name, etc. This would allow you to create a class and then use content assist to fill in the details specific to the class.
Previous Topic:Initializing project state error
Next Topic:Failed to load JNI library
Current Time: Wed May 22 16:57:30 EDT 2013
Powered by FUDForum. Page generated in 0.01763 seconds
