Home » Modeling » Epsilon » How to run EVL 'fix' when using eunit?(How to run EVL 'fix' when using eunit?)
How to run EVL 'fix' when using eunit? [message #1001477] Wed, 16 January 2013 14:49 Go to next message
Peter Mielke is currently offline Peter Mielke
I am currently using eunit and EVL to validate a model. The validation (check: ) portion of the EVL is being executed and failure traces are displayed, but I do not see that the EVL 'Fix' is executed/available. Does anyone know how to enable the execution/display of the fixes?
Re: How to run EVL 'fix' when using eunit? [message #1001512 is a reply to message #1001477] Wed, 16 January 2013 16:19 Go to previous messageGo to next message
Antonio Garcia-Dominguez is currently offline Antonio Garcia-Dominguez
The fixes are integrated with the Eclipse "quick fix" facilities, and invoking them in the same way would probably require writing a custom Java tool.
As a workaround for this limitation in EUnit, I suggest that you extract the code in the fix to an EOL operation and then invoke the operation normally from the fix and the EUnit test.
Would that work for you?
Re: How to run EVL 'fix' when using eunit? [message #1001540 is a reply to message #1001512] Wed, 16 January 2013 17:30 Go to previous message
Antonio, thanks for the quick reply.
I can test the 'fix' portion of EVL via Edit->Validate...
or try your suggestion of using an EOL operation in my free time Smile
Just wanted to know if I was missing something in the eunit setup.
Previous Topic:[EVL] Constraint wide Variables
Next Topic:Sync EVL validation result with text editor
Current Time: Tue May 21 20:28:41 EDT 2013
Powered by FUDForum. Page generated in 0.01588 seconds
