Home » Modeling » OCL » Writing ocl for Metaclass association
Writing ocl for Metaclass association [message #1001501] Wed, 16 January 2013 15:49 Go to next message
Jeni Martin is currently offline Jeni Martin
I am creating a profile, and my profile has three stereotypes. FR, NFR and Relation. FR and NFR are the extension of metaclass Class and Relation is the extension of metaclass Association. How can i define OCL constraints that says the Relation must be between FR and NFR? (each instance of FR is in relation with 0..* instance(s)of NFR.
Re: Writing ocl for Metaclass association [message #1001511 is a reply to message #1001501] Wed, 16 January 2013 16:13 Go to previous messageGo to next message
Seem like you want a Relation constraint that its base Association has
FR applied at one end and NFR applied at the other.
NB. UML requires automated definition of base_Association and
extension_Relation to facilitate stereotype navigation.
You will find that this is ropey at best in the Juno release of the OCL
editors and Papyrus. OCL should be fixed in Kepler M4. Papyrus and OCL
should work together for Kepler.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=398333 raised so that this
is tested for Kepler.
Ed Willink
On 16/01/2013 20:49, Jeni Martin wrote:
> Thanks
Re: Writing ocl for Metaclass association [message #1001521 is a reply to message #1001511] Wed, 16 January 2013 16:32 Go to previous messageGo to next message
Thank you so much for reply. But how can I even write the ocl for this specific constraint(it's syntax)?
I know that the baseclass has endtype property., but I don't know how I can write it.
Re: Writing ocl for Metaclass association [message #1001536 is a reply to message #1001521] Wed, 16 January 2013 17:12 Go to previous messageGo to next message
Something like
context Relation
inv HasFR:
base_Association.memberEnd->exists(getStereotypeApplication(FR) <> null)
inv HasNFR:
base_Association.memberEnd->exists(getStereotypeApplication(NFR) <> null)
Element.getStereotypeApplication(Stereotype) is part of the MDT/UML2 API.
Ed Willink
> specific constraint(it's syntax)? I know that the baseclass has
Re: Writing ocl for Metaclass association [message #1006337 is a reply to message #1001536] Wed, 30 January 2013 16:38 Go to previous message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Hi<br>
<br>
The following should be possible in Kepler M5. It was created using
the latest Papyrus development code using the EssentialOCL editor
integration. The OCL text has therefore been semantically checked
(at M2). Actual functionality at M1 is still work in progress.<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&amp;id=13164" alt=""><br>
<br>
No need to lose type safety with getAppliedStereotypes.<br>
<br>
    Regards<br>
<br>
        Ed Willink<br>
<br>
<br>
<br>
On 16/01/2013 22:12, Ed Willink wrote:
<blockquote cite="mid:kd78la$ji3$1@xxxxxxxxe.org" type="cite">Hi
<br>
<br>
Something like
<br>
<br>
context Relation
<br>
inv HasFR:
base_Association.memberEnd-&gt;exists(getStereotypeApplication(FR)
&lt;&gt; null)
<br>
inv HasNFR:
base_Association.memberEnd-&gt;exists(getStereotypeApplication(NFR)
&lt;&gt; null)
<br>
<br>
MDT/UML2 API.
<br>
<br>
<br>
<br>
        Ed Willink
<br>
<br>
<br>
<blockquote type="cite">Thank you so much for reply. But how can I
even write the ocl for this specific constraint(it's syntax)? I
how I can write it.
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
  • Attachment: bhhgdhjd.png
    (Size: 8.70KB, Downloaded 24 times)
Previous Topic:[Announce] Eclipse OCL 4.0.2 (Juno) SR2 RC2 is now available
Next Topic:[Announce] Eclipse OCL 4.1.0 (Kepler) M5 is now available
Current Time: Sat May 25 16:23:47 EDT 2013
Powered by FUDForum. Page generated in 0.01749 seconds
