Home » Eclipse Projects » Eclipse 4 » ViewPart's @PostConstruct createControls() not called
ViewPart's @PostConstruct createControls() not called [message #1001493] Wed, 16 January 2013 15:24 Go to next message
Joel Becker is currently offline Joel Becker
I defined a MPartDescriptor in my Application.e4xmi, then in a Handler I get an EPartService injected which I use to createPart() and showPart(). I can then get my actual ViewPart impl object from mpart.getObject(). The problem I have though is that my ViewPart class's createControls() is never called. It is annotated with @PostConstruct (the ViewPart class was created with the Eclipse 4 ViewPart wizard). Any ideas how I can get the method to be called? (I can't call it myself because I don't have the parent Composite that must be passed in...)
Re: ViewPart's @PostConstruct createControls() not called [message #1001526 is a reply to message #1001493] Wed, 16 January 2013 16:43 Go to previous messageGo to next message
Frank Benoit is currently offline Frank Benoit
Member
I add the part to its new parent part stack, like this
	    MPartStack stack = (MPartStack) modelService.find("org.eclipse.e4.primaryDataStack", appl);
	    MPart part = partService.createPart("...");
	    stack.getChildren().add(part);
	    partService.showPart(part, PartState.ACTIVATE);
cu
Frank
Re: ViewPart's @PostConstruct createControls() not called [message #1001534 is a reply to message #1001493] Wed, 16 January 2013 17:09 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
If @PostConstruct is not called please check if the bundle in question
does an import-package for javax.annotation, do not use require bundle!
You need to have a import-package javax.annotation 1.0.0
Tom
Am 16.01.13 21:24, schrieb Joel Becker:
Re: ViewPart's @PostConstruct createControls() not called [message #1001918 is a reply to message #1001534] Thu, 17 January 2013 09:59 Go to previous messageGo to next message
Joseph Carroll is currently offline Joseph Carroll
@Tom
I am not familiar with the issue of required vs. imported javax.annotation. Is there a bug or some other documentation where I can read a little more about this?
JD
ps. - I haven't run into an issue, but I want to make sure I don't Smile
Re: ViewPart's @PostConstruct createControls() not called [message #1001951 is a reply to message #1001534] Thu, 17 January 2013 10:47 Go to previous messageGo to next message
Thanks, Frank and Tom. I was missing the javax.annotation package import.
Re: ViewPart's @PostConstruct createControls() not called [message #1002005 is a reply to message #1001918] Thu, 17 January 2013 12:39 Go to previous message
IIRC there's even an FAQ,
http://wiki.eclipse.org/Eclipse4/RCP/FAQ#Why_isn.27t_my_.40Inject-able.2F.40PostConstruct_methods_being_injected.3F
Tom
Am 17.01.13 15:59, schrieb Joseph Carroll:
> @Tom
> JD
> ps. - I haven't run into an issue, but I want to make sure I don't :)
Previous Topic:Putting a PerspectiveStack on a Part
Next Topic:No menu when launching newly built e4 application
Current Time: Tue May 21 16:39:24 EDT 2013
Powered by FUDForum. Page generated in 0.02341 seconds
