Home » Language IDEs » CDT » make error with -l library flag
make error with -l library flag [message #1001009] Tue, 15 January 2013 16:13 Go to next message
Ray Mitchell is currently offline Ray Mitchell
I'm using Eclipse CDT on Ubuntu with the standard Linux GCC Toolchain and I need to link in the math library. Using the -l linker flag does eliminate the "unresolved reference" errors for the math library function calls in my code but whenever I do use the -l linker flag I get the following:
Building target: Ex15a
Invoking: GCC C Linker
gcc -l -o "Ex15a" ./Ex15a1_main.o
gcc: error: Ex15a: No such file or directory
make: *** [Ex15a] Error 1
Ray
[Updated on: Tue, 15 January 2013 18:29]
Report message to a moderator
Re: make error with -l library flag [message #1001233 is a reply to message #1001009] Wed, 16 January 2013 04:42 Go to previous messageGo to next message
Axel Mueller is currently offline Axel Mueller
The linker flag "-l" needs the name of the lib! In your case it is "m"
Please follow the instructions here
http://wiki.eclipse.org/CDT/User/FAQ#How_do_I_add_an_external_library_to_my_C.2B.2B_project.3F
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: make error with -l library flag [message #1001486 is a reply to message #1001233] Wed, 16 January 2013 15:12 Go to previous message
Thanks for your help. I tried the first two solutions but neither worked. Thankfully the third solution did work.
Previous Topic:copy Cygwin Toolchain
Next Topic:Problem with custom build step
Current Time: Sat May 25 09:29:52 EDT 2013
Powered by FUDForum. Page generated in 0.02655 seconds
