Home » Modeling » UML2 » How to save to .uml file using an older UML version?
How to save to .uml file using an older UML version? [message #1001207] Wed, 16 January 2013 03:47 Go to next message
Andreas Brieg is currently offline Andreas Brieg
Member
I'm using org.eclipse.uml2.uml 4.0.1 to create an UML model. The model is saved in a .uml file with xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML". I would like it to be saved with xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML".
My code for creating the resource currently looks like this:
Resource resource = UML302UMLResource.Factory.INSTANCE.createResource(uri);
And I save it with no options:
resource.save(null);
What do I have to do, to save my model with the XML Namespace of UML302UMLResource? Do I have to specify an option. If yes, which one is it?
[Updated on: Wed, 16 January 2013 03:47]
Report message to a moderator
Re: How to save to .uml file using an older UML version? [message #1001246 is a reply to message #1001207] Wed, 16 January 2013 05:11 Go to previous messageGo to next message
I presume your message has a typo because your request the current nsURI.
Your activities are possibly confused by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=389542 which identifies
that on 4.0.1 createResource is broken for UML; use a more recent
maintenance version.
For the current version, I would expect to do
ResourceSet.createResource(URI)
I thought there was an MDT/UML2 enhancement Bugzilla open for previous
versions but I can't find it.
Anyway, the reality is that unless someone comes forward to fund
multi-version save it's unlikely to happen.
Once implemented, for a previous version I would expect to do
ResourceSet.createResource(URI, String)
where String is the required content type.
Ed Willink
> be saved with xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML".
> Resource resource =
> is it?
> Thanks
Re: How to save to .uml file using an older UML version? [message #1001290 is a reply to message #1001246] Wed, 16 January 2013 07:07 Go to previous message
Member
Thanks for your answer Ed. I meant xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" as the xml namespace the I would like to have. I corrected this here in the forum. So as there is no easy workaround, I will fall back on using an older version of the UML API.
Previous Topic:UML save to *.uml file
Next Topic:XMI datatype representation
Current Time: Tue May 28 17:46:07 EDT 2013
Powered by FUDForum. Page generated in 0.03417 seconds
