| Problems with Starting a Project [message #1000863] |
Tue, 15 January 2013 10:06  |
Bilbo Baggins Messages: 1 Registered: January 2013 |
Junior Member |
Good morning,
I'm having problems with opening a project and also with importing an existing one. I'm using Windows 7 and my "java -version" is 1.7.0_09, according to the prompt.
First, I decompressed the archive of Eclipse in the Root folder (C:\). The first problem I obtain is that, according to Eclipse, the HOME variable in EGit is not set. Then, following these instructions of the Eclipse user guide, I set C:\ as HOME variable.
But I continue to obtain the following errors: when I try to create a new project, clicking in the wizard on "Finish" nothing happens. When I try to import an existing one, nothing still happens. The "funniest" thing is that if I try to import it again, Eclipse says that it is already in the workspace; even if I delete the folder of a project I created (which Eclispe didn't open), trying to create a new one with the same name, Eclipse replies that "a project with that name already exists".
If I have to be honest, I'm quite desperate. Thank you for your help!
FUDForum. Page generated in 0.02326 seconds
