Home » Modeling » TMF (Xtext) » What is best way to get reference of JvmAnnotationType in inference?
What is best way to get reference of JvmAnnotationType in inference? [message #904208] Mon, 27 August 2012 22:19 Go to next message
Jeeeyul Lee is currently offline Jeeeyul Lee
JvmTypesBuilder seems not to support JvmAnnotationType.
So I created it myself:
val annoType = createJvmAnnotationType =>[
	it.packageName = "java.lang"
	it.simpleName = "SuppressWarnings"
var annoTypeRef = createJvmAnnotationReference => [
	annotation = annoType
	values += createJvmStringAnnotationValue => [
		values += "all"
It causes dangle problem, because this reference is not contained by resource.
I tried to inspect, but it seems to I am wandering so deep and internal mechanism.
Can anyone suggest best approach?
Re: What is best way to get reference of JvmAnnotationType in inference? [message #904286 is a reply to message #904208] Tue, 28 August 2012 03:05 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven Efftinge
Did you try a clean build?
Am 8/28/12 4:19 AM, schrieb Jeeeyul Lee:
> values += "all"
> resource.
> mechanism.
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Need professional support for Xtext and EMF?
Blog : blog.efftinge.de
Re: What is best way to get reference of JvmAnnotationType in inference? [message #904295 is a reply to message #904286] Tue, 28 August 2012 03:28 Go to previous messageGo to next message
I think I did not explain my problem correctly.
I'm writing a JVM model inferrer,
I want to add an annotation(@SuppressWarning("all")) to my inferred type.
JvmTypesBuilder xtend extensions provides newTypeRef() method to create or reuse JvmTypeReference easily.
But it supports only against of JVMGenericType, not JvmAnnotationType.
So I tried to create JvmAnnotationReferernce by myself.
		values += "all"
in above code, annoTypeRef is not contained by any resource, because I didn't. (because I don't know which resource is appropriate)
So inferring causes an error log which reports isolated model from resourceset problem.
I tried to inspect JVMTypesBuilder and TypeReferences,
It's to complex to me,
So I think that I may going wrong way or too deep.
Re: What is best way to get reference of JvmAnnotationType in inference? [message #904299 is a reply to message #904295] Tue, 28 August 2012 03:38 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
It needs to be added to<code>
org.eclipse.xtext.common.types.JvmAnnotationTarget.getAnnotations()<br>
<br>
</code>
<div class="moz-cite-prefix">On 28/08/2012 9:28 AM, Jeeeyul Lee
wrote:<br>
</div>
<blockquote cite="mid:k1hrvq$4pt$1@xxxxxxxxe.org" type="cite">I
<br>
<br>
<br>
inferred type.
<br>
<br>
<br>
JvmAnnotationType.
<br>
<br>
<br>
<br>
<br>
val annoType = createJvmAnnotationType =&gt;[
<br>
<br>
<br>
<br>
<br>
var annoTypeRef = createJvmAnnotationReference =&gt; [
<br>
<br>
    values += createJvmStringAnnotationValue =&gt; [
<br>
        values += "all"
<br>
<br>
<br>
<br>
<br>
appropriate)
<br>
<br>
<br>
<br>
I tried to inspect JVMTypesBuilder and TypeReferences, It's to
complex to me, So I think that I may going wrong way or too deep.
<br>
</blockquote>
<br>
</body>
</html>
Re: What is best way to get reference of JvmAnnotationType in inference? [message #904323 is a reply to message #904299] Tue, 28 August 2012 04:40 Go to previous messageGo to next message
It was done by using TypeReferences
var rootType = root.toClass(typeName)[
	annotations += createJvmAnnotationReference => [
		it.annotation = references.findDeclaredType(typeof(SuppressWarnings), root) as JvmAnnotationType
		it.values += createJvmStringAnnotationValue => [
			values += "all"
Re: What is best way to get reference of JvmAnnotationType in inference? [message #1000853 is a reply to message #904323] Tue, 15 January 2013 09:46 Go to previous message
Alan Alberghini is currently offline Alan Alberghini
Thanks for the solution, I was looking for it!
However, I'm facing another similar issue with a JvmTypeReference: I need a "void"-kind JvmTypeReference for the return type of a method I'm inferring, but I keep getting various errors when testing the plugin.
Anyone has any insight?
Edit: for some strange reason one of my previous forum searches got stuck and I couldn't find other relevant posts.
Found the solution here.
Sorry for the inconvenience.
[Updated on: Sat, 26 January 2013 12:33]
Report message to a moderator
Previous Topic:Use xmi elements inside the dsl
Next Topic:xtext check annotation issue
Current Time: Tue May 21 11:46:39 EDT 2013
Powered by FUDForum. Page generated in 0.02330 seconds
